changing out heads/ jugs
Old Jan 9, 2014 | 08:59 AM
02 softail's Avatar
02 softail
Stage IV
Default changing out heads/ jugs
I have a 02 softail 88" and have an opportunity to get a set of 96" heads and jugs off 2012 will they work on my 02
Old Jan 9, 2014 | 09:41 AM
Lundee's Avatar
Lundee
Won't help. They are the same bore. The stroke is longer on a 96". Bore out your stockers to a 98". Smile every time you spank a 96"er.
Old Jan 9, 2014 | 10:01 AM
QC's Avatar
QC
Take the heads. You will need new intake flanges for them to fit right, but only about $20 for a pair. Talk to Scott at Hillside Performance ( a sponsor) about a 98" kit.
Old Jan 9, 2014 | 10:23 AM
djl's Avatar
djl
Lundee is right about the cylinders but the heads from the 96" motors are much better than the early TC88 heads. Snag them if the price is right, clean them up if they have some mile, SERDI valve job, new guide seals, and install them with a .030" head gasket along with a set of S&S 551 cams. You will need to rejet if carbed or purchase a tuner if EFI. For this upgrade, the Dobeck/Techlusion TFI GEN3 will work but if budget will allow, TTS Mastertune and a dyno tune would be better. You can spank a stock or Stage I 96"er with that setup.
Or, bore the take off cylinders to 95" as Lundee suggests, install with a set of SE cast flat top pistons, follow the same recipe with heads; even better. Change cam choice to S&S 570. You could bore to 98" but then you are limited in piston choices. If you wanted to go to 98", send the take off cylinders to Hillside; they have a pretty good program for boring and fitting Wiseco pistons.
I would take advantage of getting the later heads if they are cheap. They will make a difference on an 88"er if combined with the right cam set. I would not install the heads and run the OEM cams; not worth the effort.
Old Jan 9, 2014 | 02:59 PM
tbonetony06's Avatar
tbonetony06
Have the heads flowed, ported and polished while they are off and you have the chance.
aposto
Engine Mechanical Topics
Apr 18, 2014 06:42 AM
mlnevill
Exhaust System Topics
Jul 22, 2013 12:32 PM
fastbagger
Sep 17, 2012 09:04 AM
timberland
Feb 26, 2012 04:40 AM
softail99custom
EVO
Jan 21, 2010 08:45 AM
