piston
Old Apr 16, 2014 | 11:20 AM
aposto's Avatar
aposto
Default piston
thinking about upgrading my 88 to 95. want to run andrews 37 they say they should run 9.7 - 9.8.1 compression. would wiseco domed pistons fit with the stock heads. that would bring it up to 9.5.1 then use 030 gasket should get me close to the compression i want. the bike is a 06 streetglide
Old Apr 16, 2014 | 02:24 PM
djl's Avatar
djl
Depends on the dome volume and the chamber volume. Best to CC the head and use a compression calculator to figure out what you need to do. Most TC heads will run 85-86cc but I have seen them measure 89-90cc. Using domes and maintaining chamber volume is a better approach to set compression than using flat top pistons and cutting .060".
Old Apr 16, 2014 | 09:19 PM
magnum629c's Avatar
magnum629c
From what I here its best to run flat tops pistons.. I would send ur jugs to to big Boyz and have them bored out for 150$ new pistons 200$ and have him port the heads 300$ and for 70$ he decks the heads and u can set settle compression anywhere u want. The hole job would run u around 700$
Old Apr 17, 2014 | 05:21 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We have a good client in Worcester, that we set up with a 37 last year.
Our Stage II Heads/10.0 cr/98"/51 HPI/Bassani 2 into 1/tuned at a shop in Manchester, NH.........108/112, sae.
Andrews wants to see the dyno report........I need to get that over to them sometime.
Scott
Old Apr 17, 2014 | 09:30 AM
djl's Avatar
djl
Using flat top pistons is one way to get there but requires that chamber volume to be reduced to 76cc; a .050" cut on the heads, to set CR at 10:1 per Scott's example in his post. That deep a cut can make intake manifold alignment difficult as well as render the heads useless in the future for a different cam set. Working the heads and ending up with say an 88cc-90cc chamber and a domed piston does not affect intake manifold alignment and makes the heads useable in the future with different cam sets which also makes that heads more attractive to a future buyer as he will not be limited in cam choices.
Old Apr 17, 2014 | 01:36 PM
fidel's Avatar
fidel
i just build mine i go with andrews 57 same as 37 more lift 10 to 1 comp
ported head 1.9 intake valve stock exhaust valve 98 ci supertrapp 2 in 1 20 disc closed end cap ist ignition ( carb bike ) not break yet but amasing change in power from 88 with 26 cam
Old Apr 18, 2014 | 05:03 AM
Hillsidecycle.com
Sponsor
Want more lift?
We, at this time are setting up a 98"er, once again for a client from Mass.
Wood 408/ 10.6 cr/roller rockers/98"/our Stage III Super-Tour Heads/55 mm HPI.
Crank is pinned, and welded.
Gonna' be a beast.
Scott
Old Apr 18, 2014 | 06:42 AM
prodrag1320's Avatar
prodrag1320
use 22851-99A SE pistons (9.4-1),then mill the head .027,as long as the head was 85cc`s to begin with,this should put you right in the 9.8-1 area (DONT do any machining without cc`ing heads first)
pdevore
Engine Mechanical Topics
29
Dec 9, 2016 09:28 AM
02 softail
Jan 9, 2014 02:59 PM
timberland
Exhaust System Topics
Feb 26, 2012 04:40 AM
Joker65
Jan 30, 2012 06:51 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
