Fat Boy Intake Question
Old Jan 23, 2014 | 12:38 PM
Scudda's Avatar
Scudda
Default Fat Boy Intake Question
I bought my 2005 Fat Boy used. It looks like it had a stage one kit done at some point....V&H Long shots...and it looks like they used a stage 1 air intake with the stock cover. I can only guess that a stage one download was done as there is no fuel controller on the bike. The bike runs great.....the plugs always look good and there is no decel popping...so my question is.....I want to change out the air intake to something nicer like The burst collection intake or something from RS.....since the stage one was already done do you think I could run into a lean fuel issue by doing this?
Old Jan 23, 2014 | 01:58 PM
Warren9073's Avatar
Warren9073
If in fact the stage one was already done I cant imagine changing the air cleaner will increate your intake at all. I don't think there is that much difference in the flow rate of most of the aftermarket intakes.
Old Jan 23, 2014 | 02:16 PM
mswing1234's Avatar
mswing1234
I have seen it mentioned on The Forum before that you may be able to have your local H-D dealer run your VIN and see if there is any record of a Stage 1 download on that bike. It won't hurt to ask.
Old Jan 23, 2014 | 03:56 PM
olongapo1's Avatar
olongapo1
The previous responses are correct. It's possible that your local HD dealership can access the maintenance database and retrieve previous maintenance performed by other HD dealerships. I've experienced this once. Additionally Stage 1 intakes, for the most part, are all basically the same in performance. You should not see any major difference.
Old Jan 24, 2014 | 04:28 AM
Scudda's Avatar
Scudda
Thanks guys! I will try the dealer to see if they can run the vin.
Old Jan 24, 2014 | 04:36 AM
ynots's Avatar
ynots
Ditto, if you already have a high flow ac go for it
smokingjoe
Mar 22, 2019 05:19 PM
Nordal
Aug 28, 2013 07:42 AM
ashenfang
Sep 26, 2008 07:03 PM
srigas
Exhaust System Topics
Apr 12, 2007 10:35 PM
BLAZE
Nov 17, 2005 12:10 PM
