The Shotgun Shock Installation Thread
Old Mar 22, 2014 | 02:23 PM
  #31
patharley's Avatar
patharley
Originally Posted by 24v
That sucks. I would get a new bolt, and try to run a tap up in there. Maybe you can save the threads?
X2.
Take 5 minute to run a tap in and put some locktite.
Old Mar 22, 2014 | 03:14 PM
  #32
24v's Avatar
24v
Originally Posted by Village Idiot™
Could the threads in the hole possibly be fine and just the bolt cross threaded?
More than likely the threads are stretched from you bending the wrench.
Old Mar 24, 2014 | 10:05 AM
  #33
Village Idiot™'s Avatar
Village Idiot™
How much should I worry about belt adjustment? Since the swingarm pivots, the belt tightens an loosens depending on where the swingarm sits, so will I have to worry about the belt being too loose when I dump it?
Old Mar 24, 2014 | 10:15 AM
  #34
24v's Avatar
24v
I just adjust my belt for the ride height I spend the most time at.
Old Mar 24, 2014 | 11:00 AM
  #35
jam436's Avatar
jam436
I don't think your belt is going to tighten or loosen significantly just by changing heights. The swing-arm rotates up and down, not in and out...
Old Mar 24, 2014 | 11:15 AM
  #36
24v's Avatar
24v
It actually does, try it. It is not a huge amount, but there is definitely a noticeable difference.
Old Mar 24, 2014 | 11:18 AM
  #37
'05Train's Avatar
'05Train
No washers on the shoulder bolts, and both washers on the front side of the front bolts.
Also, jack the bike up, wedge a wrench against the ground, then slowly lower the bike to break loose the rear bolts.
Old Mar 24, 2014 | 12:01 PM
  #38
Village Idiot™
It does rotate, and since it starts at close to a line that's parallel with the rest of the bike when stock, riding it at stock height or lower rotates it upwards. Since the pivot point for the rotation isn't on the point where the opposite end of the belt connects to (the primary drive pulley), the distance from the rear pulley decreases as the swingarm pivots up.
Being as how this is the first HD I've modded and all my other bikes have been chain driven, I'm not too familiar with belts. I know that if the chain tension was off by a little bit, you could feel drive line lash in the chain when accelerating. From what I've heard of people losing teeth to improperly adjusted belts or rocks in the pulleys, I'd want to make sure that it's not going to do anything bad from the difference in slack due to raising or lowering the bike. But there's enough people with adjustable suspension on their Softails to give advice on that.
Old Mar 24, 2014 | 12:38 PM
  #39
24v's Avatar
24v
That's a great idea.
Old Mar 24, 2014 | 03:20 PM
  #40
Yo Nadz's Avatar
Yo Nadz
Going to try and conquer this beast tomorrow. I'll input any advice I can.
