LED Lights
Old Mar 23, 2014 | 03:01 AM
hdgzr's Avatar
hdgzr
on my 2011, the load stabilizer wasn't required...
Old Mar 23, 2014 | 06:31 AM
Aaresz's Avatar
Aaresz
Didn't needed a load stabilizer in mine either. If I remember correctly Custom Dynamics' website will help you determine which bikes may need one by model and year.
Old Mar 23, 2014 | 06:39 AM
str8shuutr45's Avatar
str8shuutr45
I have the HD LED all the way around on my Heritage. I started with the daymaker head and passing light. A year later installed the bright lights strobe LED taillights and HD front and rear LED turn signals. I also installed the HD wiring harness front and rear to tie in the passing lights with the high beam an the rear turn signals with the rear brake light.
Old Mar 23, 2014 | 07:48 AM
24v's Avatar
24v
Originally Posted by Bone Doc
A load stabilizer is only necessary if the CAN bus is present. The OP did not specify what year his bike is. IIRC, the CAN bus was introduced in the 2011 model year. Others, please correct me if the CAN bus was introduced in a different model year.
Without going into detail about the CAN bus, suffice it to say it is sensitive to voltage ("load") changes caused by modifications to any electrical component/system, including the bikes lighting. Load stabilizers correct these voltage differences so the CAN bus system does not suspect a malfunction.
You have this backwards. Can Bus bikes DO NOT need a load stabilizer.
The reason you use a load stabilizer is because LED's cause way less resistance. Less resistance makes a flasher relay flash quicker. So, when you put LED's into a system that uses a flasher relay the indicators will flash quicker. The load stabilizers just add resistance.
Can Bus systems do not use a flasher relay for the turn signals, it is controlled by the Body Control Module. However, they have programmed this to still see a bulb out, and when that happens the indicator on your dash will blink fast. The turn signal bulbs still blink normal speed though.
So, in short, you can use the stabilizers on a CAN BUS bike if you want, but it is in no way required.
24v's Avatar
24v
Originally Posted by balloo
Please help me understand the "load stabilizer" - - the HD web site is noted "plug & play", which I assume means that nothing else is necessary. I don't want to buy something, and then find out more is needed.
Thanks,
Balloo
The HD turn signal LED lights are designed to work with this electrical system and do not require load stabilizers.
Old Mar 23, 2014 | 08:20 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I have Custom Dynamics r/s/t lights. Great company, great lights. So easy to install. I would have went with a Truck Lite headlight but they don't make a 5" one, so I had to go with the HD version.
Old Mar 23, 2014 | 09:20 AM
Blk and Chrome's Avatar
Blk and Chrome
I have the HD LED headlight and Custom dynamics for all the rest. they are way brighter than the regular bulbs
Old Mar 23, 2014 | 09:38 AM
ChickinOnaChain
CDs lights...or mine...have 48 bulbs, which may help make the brighter.
Old Mar 23, 2014 | 10:58 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I have replaced all the lights on my Heritage with HD LED's. They are ell designed and are just pug and play. Take out the old bulbs, put in th new ones. The change in visibility is amazing.
Old Mar 23, 2014 | 11:20 AM
Bone Doc's Avatar
Bone Doc
I apologize to all for the misinformation. 24v, thanks for setting the record straight. I should have known this since I have LED lights all the way around on my 2012 FLSTC, to include the fender tip lamps, and a load stabilizer wasn't required.
