LED Lights
Old Mar 24, 2014 | 07:17 AM
  #31
24v's Avatar
24v
BTW, here is another quick reason I am hesitant to run load equalizers.
"WARNING
Load equalizers generate heat when in use. It is imperative that the signals
not be operated for extended period of time (i.e. four-way flashers).
Extended operation will cause the load equalizer to overheat. Aside from
the resultant loss of turn signal function, overheated equalizers pose a fire
hazard."
From Kuryakyn.
http://www.cruisercustomizing.com/in...es/KY-4810.pdf
Old Mar 24, 2014 | 09:23 AM
  #32
jam436's Avatar
jam436
Originally Posted by 24v
Explain to me what is "not working right"? The code and fast blinking is only to let you know you have a bulb out. I checked, bulb still works, no harm done. My blinkers operate fine, and none of the rest of the system is affected. I'd rather have that than add resistance back into the system. To each their own.
What I was referring to was the fast-flashing dash.
That's not normal.
But like you said "to each his own".
If it doesn't bother you, all fine and good.
I just wanted mine to work as intended...
Besides, leaving the fast-flash as is, how will you know when you really DO burn out a bulb?
Old Mar 24, 2014 | 10:18 AM
  #33
24v's Avatar
24v
By visually inspecting my motorcycle.
dyna bob 583
Electrical/Lighting/Alarm
Jun 15, 2016 12:25 AM
The Dali
Apr 18, 2014 01:49 PM
maccid
Jun 30, 2013 07:44 AM
BohicaAZ
Jan 7, 2011 07:17 PM
Mr. Wizard
Oct 9, 2009 03:48 PM
