Radio options
Old Apr 1, 2014 | 09:31 AM
inkpen00's Avatar
inkpen00
Default Radio options
I havent seen many softails with a radio on them except if it was just speakers connected to an iPod or mp3 player. But I have been looking for an actual radio that I can hook up and be some what hidden on the bike. I saw this online. Has anyone had any experiances with it?
Jensen Weatherproof JHD910BT Bluetooth Radio
JHD910BT BLUETOOTH MINI RADIO
12V DC power
AM/FM electronic tuner (US/Euro)
Front and rear panel audio Aux-in for use with iPods®, MP3 players and portable CD players
Listen to music your own way through Bluetooth enabled stereo headphones or built-in 15W stereo amplifier
Works with most factory installed speaker/antenna systems or our JENSEN speakers (antenna sold seperately)
7-Channel NOAA weatherband tuner
Weather Alert automatically switches to WB mode when NOAA warning broadcast is received
2-wire connection prevents battery drain when vehicle is not in use
Clock runs up to 30 days when vehicle battery is disconnected
Corrosion and UV-resistant faceplate
30 programmable station presets (18FM, 12AM)
Built-in job site work timer
Electronic seek up/down/volume/bass/treble/balance
12/24 hour clock
Backlit controls with selectable amber or green illumination colors
Daylight readable display with wide viewing angle
One-touch audio mute
Dimensions: 53/16" W x 33/8" H x 17/8" D NOTE: Can be used with 7/8", 1" and 11/4" bar mount PART #4401-0051
Old Apr 1, 2014 | 09:33 AM
inkpen00's Avatar
inkpen00
I want to be able to wire up speakers to the lower leg fairings that I added and also in the lids of my stretched touring bags.
Old Apr 1, 2014 | 10:53 AM
Knuckles73's Avatar
Knuckles73
looks like it has to be mounted into something...like a fairing or bag mount. if you wanna run 4 speakers I didnt see where it had 4 channels to do that. All the above solved..you could put it in the HD boom audio case, its magnetic and small...just remove it when done riding.
Old Apr 1, 2014 | 11:00 AM
inkpen00's Avatar
inkpen00
Well I was trying to avoid running a fairing but I wanted something fixed to the bike. I did notice on that radio it had a 2 channel output but for some reason it wasnt in the description. could I run the radio to an amplifier connect the 4 speakers? Im not very audio savvy.
Old Apr 1, 2014 | 11:43 AM
Ink83's Avatar
Ink83
Have you thought about using head phones? The sound won't disappear in the wind at speed, and the world doesn't have to listen to your taste in music lol...the first one works in your favor, the second in everyone's else's favor...everyone wins!!
Not to mention you don't need to worry at all about buying all that audio system or the worry of where to mount it all
Old Apr 1, 2014 | 01:15 PM
inkpen00's Avatar
inkpen00
I was talking to a buddy that used to work with audio systems and installed them (which i never knew). But he lead me to this set up...
Clarion M303 Headunit or the Sony DSX-MS60 which would mount in my saddle bag (shouldnt take up too much room)
Clarion MW1 Marine Remote Control or the Sony RM-X60M/L. I would mount the remote control in where the ignition switch is and relocate the ignition switch to the horn location.
Both setups will be out of the way, speakers arent mounted on the handlebars or on the crashbars. They will be in the lower fairings and in the saddle bag lids. And even better NO FAIRING!
tmurray9999
Aug 26, 2015 06:36 PM
Timmy B
Feb 12, 2014 08:13 PM
Bonzaiii
Audio Systems
Oct 22, 2012 07:19 AM
r8rs4lf
Sep 6, 2008 11:12 AM
jackster007
Nov 26, 2006 12:45 PM
