Braided brake line
Old May 1, 2014 | 11:10 AM
tmilo1000's Avatar
tmilo1000
Default Braided brake line
Should be a simple question. The braided line screws into the banjo bolt. Should Teflon tape or some other type of sealer be used to prevent leaks?
Old May 1, 2014 | 11:15 AM
rbeamj's Avatar
rbeamj
No Teflon sealer should be used on brake lines. The banjo bolt shoul have crush washers. One on each side of the eyelet.
Old May 1, 2014 | 11:30 AM
tmilo1000's Avatar
tmilo1000
The banjo bolt does have crush washers on each side that screw into the master cylinder. The brake line is not attached to the banjo bolt and screws into the banjo bolt. Kind of like a male to female fitting.
Old May 1, 2014 | 08:29 PM
lazyboy09's Avatar
lazyboy09
I'm not sure I understand your last post, but no sealant of any kind should ever be used on a brake system.
Old May 1, 2014 | 08:56 PM
asm481's Avatar
asm481
I think you will find that the threads here are a flare type fitting which wants metal to metal meeting. Thread sealant can cause more leaking then it can fix.
stal94gt
Mar 12, 2017 09:44 AM
Jpatterson317
Feb 27, 2017 08:31 AM
goatfarmer
Mar 10, 2015 04:12 AM
99%r
Aug 18, 2013 08:49 PM
ed gien
Jan 18, 2011 08:18 PM
