oil change
Old May 9, 2014 | 09:36 AM
dimefan's Avatar
dimefan
I just use the filters that have the nut on the end so that I can just remove it with a socket.....never had any issues getting it off.
Old May 9, 2014 | 09:39 AM
Low n Loud's Avatar
Low n Loud
Stop putting the filter on so tight!
Old May 9, 2014 | 10:46 AM
yzergod's Avatar
yzergod
And make damn sure you use Amsoil and an Amsoil filter!!! If you don't, the Amsoil ****'s will execute several babys because you didn't!!
Old May 10, 2014 | 07:03 AM
balfbaby's Avatar
balfbaby
4th Gear
The dealer did the last oil change.
Old May 10, 2014 | 07:06 AM
balfbaby's Avatar
balfbaby
4th Gear
In 12 yrs this is the first time I've had a problem. And the dealer did the last oil change.
Old May 10, 2014 | 07:08 AM
HDmikie's Avatar
HDmikie
Originally Posted by Transporter
Just used the screwdriver yesterday for the last time, I am going to buy the K&N for now on.
Yep, K&N filters are the ticket. Remove it with a ratchet and socket. Easy!
Old May 10, 2014 | 07:16 AM
Iceman24's Avatar
Iceman24
Definitely a beotch when you can't get the old filter loose and all the 4-letter words in your dictionary won't help loosen it off. Guessing the dealer let their "prospect mechanic" do your change and probably didn't smear a bead of oil on rubber seal. Other than over-tightening, that's why filters bond/weld themselves to the block (you probably know). Also, HD does a great engineering job planning tons of room to work around your filter (not ). Like others, I switched to K&N with the nut-end and that's my best alternative. Otherwise a "rubber strap" wrench works too. Glad you got it off & road-ready.
Old May 11, 2014 | 06:14 AM
balfbaby's Avatar
balfbaby
4th Gear
Ya I think the K&N is the choice from now on. Thanks
Old May 11, 2014 | 06:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The guy who installed the oil filter most likely did not lube the gasket first, that is why oil filters get stuck.
Old May 12, 2014 | 09:00 PM
oct1949's Avatar
oct1949
**** happens,, just use one of the old methods as you did to remove it..
Iron lHorse
Jul 21, 2015 10:44 PM
kpb46
Feb 19, 2014 08:19 PM
traildog
EVO
52
Aug 11, 2013 12:09 PM
tallboy56
Oct 21, 2008 01:28 PM
DayDrivingDan
Feb 2, 2008 11:50 PM
