How important is the compensator sprocket?
Old May 8, 2014 | 04:30 PM
bill in okc's Avatar
bill in okc
Belt drives do some compensation in the belt. Other bikes have compensation built into the clutch hub instead of at the crank. I "have read" that the newer cranks need it more because they are press fit pieces - not sure if that means the crank can be tweaked easier or what. The least that can happen is the clutch engagement could become jerkier not sure what the worst might be. I replaced the clutch basket/compensation in a dry clutch bike and it needed a couple of beveled spring steel plates in the clutch to soften up the engagement. Good luck.
Old May 8, 2014 | 06:56 PM
JimGnitecki's Avatar
JimGnitecki
Originally Posted by ChickinOnaChain
I know I never had one on my older bikes. But whatever they're good for, mine went out after 10k miles. Why? Was it something I was or wasn't doing? I don't know. I was just glad it was under warranty. Maybe that's what they're good for...warranty work for the shop.
Since you have ridden Harleys both with and without the compensator, how would you describe the differences?
When riding Harleys without the compensator, did you ever experience a failure attributable to the lack of compensator?
When your compensator failed at 10k miles, what were the symptoms you heard or felt?
Jim G
Old May 8, 2014 | 07:02 PM
JimGnitecki
Originally Posted by Big Trev
How many revs have you got on for god sake, to do 51 MPH in first gear??
Only 6200 rpm! And, I repeat: this is STOCK gearing. THIS is how crazy current HD factory gearing is.
Jim G
Old May 12, 2014 | 10:18 AM
JimGnitecki
Over the weekend, as I was talking with a respected Harley builder and tuner, Mike Lozano, I asked him about the idea of losing the compensator.
Mike said he strongly dislikes that idea - says I should not do it.
Back to the idea of changing gearing via final drive change instead of via primary ratio change, I guess, since Harley doesn't appear to offer a compensator sprocket smaller than the stock one, that will fit my '14 Breakout.
Jim G
Old May 12, 2014 | 10:28 AM
24v's Avatar
24v
So are you going to change the front pulley? Also, if the change has an effect on the speedo, your tuner should be able to adjust for that I would think.
Old May 12, 2014 | 11:03 AM
ctluba's Avatar
ctluba
I went to a solid front primary sproket on my 1990 evo softail when I had to go to a 1" offset set up to accomodate my new rear end. I too was nervous that it would be a big issue. After I got the bike together I went for a rip and I didnt notice any difference in the feel of the tranny or the ride or shifting in and out of gear. The bike felt and performed the same as with the compensated sprocket.
I have since gone to an open belt primary and love it.
Solid front sprocket w no comp.
Old May 12, 2014 | 11:08 AM
JimGnitecki
Yes, AFTER a proper dyno tune by Mike Lozano, I plan to get the front pulley and drive belt changed by Mike (give me only a 6.7% gearing change ).
Mike says that I have some choices:
1. He can tune my bike using my Super Tuner Pro that came with the Stage 4 Race kit, or
2. He can tune by bike by selling me a $200 Power Vision license that works with his dealer PV license, but ties me to his shop (i.e. only $200 versus street price for my own PV, but can't make changes without coming back to Mike's shop), or
3. I can buy my own Power Vision, he can use it for the tune, and I can use it to make other future changes to the ECM (not just for tuning, since it allows manipulation of other parameters)
and
If I go with either 2. or 3. above, Mike can use the PV to correct the speedometer error created by the gearing change, saving me the cost of buying a separate device like the Dakota unit.
I have sent an email though to the forum member (iclick) who wrote the "sticky" on the Power Vision in the "Tuner" section of the forum, asking questions to make sure that making either / both tune changes and speedo correction changes does not interfere with HD dealer access to the ECM for diagnostics and for factory recall reflashes, especially since I plan to tour a bit with the Breakout (yeah, I know, it's not a tourer, but it'll suffice a couple of times per year ), and want ANY HD dealer to be able to do diagnostics if necessary while on a trip.
Jim G
Old May 12, 2014 | 11:24 AM
ctluba's Avatar
ctluba
Holy moly!!!
That is why I dont have any guages and I bought a bike with a carb!!!
Hope things go smooth and you get her set up the way you want.
Old May 12, 2014 | 12:12 PM
JimGnitecki
Originally Posted by ctluba
Holy moly!!!
There is initial complexity in getting yourself set up to electronically tune and change the bike's other computer parameters as well (e.g. speedometer calibration, head temperature at which an alarm is generated). But, the payback is incredibly better visibility and control into what your engine and overall bike are doing. Modern computer tuned cars and bikes are creating power and fuel mileage combinations that are simply impossible with manual setup and tuning.
My bike, with its Stage 4 kit, is currently giving me 43.5 to 45 mpg, for example.
Jim G
Old May 12, 2014 | 02:50 PM
24v's Avatar
24v
Buy your own power vision. And yes, the dealer will still be able to do diagnostics, etc. That is what I have on my bike, works great. I would not want to be tied to one shop.
