How important is the compensator sprocket?
And, if like me, you have a rear pulley whose finish and machining match a custom rear wheel (HD chrome Turbine wheels), you CAN'T find a pulley with a different diameter that will match!
I did all the analysis over a year ago, and found that to really change the gearing, including correcting the numerical drive ratio in the ECM programming so that the speedometer and ABS don't get screwed up, the real cost would be $1000 or more, unless you have the time, skills, and tools to handle primary and front belt pulley removal.
HD has made it very difficult and costly.
Jim G
"HD gearing is ridiculous 51 MPH in first gear" Too funny, I find the gearing to be fine, very easy to launch and ride these bikes. FYI the R1 I had would do 100 MPH in first gear everything stock, stupid Yamaha too I Guess huh....?
51 mph in 1st gear IS ridiculous. Yes, some other motorcycle and cars have similar gearing, but there is a reason for both. For the cars, it is to get the last few mpg of fuel mileage to meet CAFE standards. It DOES result in very impaired performance. For the motorcycles, it is because the bikes are "race replicas" built to be sold on the basis of your being able to do 160 to 200 mph, and they need to be geared that way in order to keep the gaps between gears sensible FOR THAT KIND OF RACE TRACK RIDING. But that makes them very impaired in NORMAL TRAFFIC riding OFF of any race track. The people that buy them either accept that or are too ignorant to understand why their bike feels so gutless around town unless they speed all the time AND keep the rpm insanely high. Of course, some people LIKE that kind of riding.
Jim G
A Rivera-Primo belt drive would be fine.
As above, the speedo & ABS weren't affected - gear indicator yes. I'm not a hard core wrencher, and I changed over in a couple of hours. In fact, it was darn right easy until I had to remove everything again to change the stator seal that was leaking. You do have to buy one tool to remove the race on the tranny, but that's available on eBay.
Well, it's actually easy, but a Primo belt drive for the BO will run you $2K+ (I got mine for 2K - list was $2400 then.
The belt drive also makes an already wide bike even wider, or at least it LOOKS like it would.
The open belt drive is also a safety hazard.
One reason that the belt drive might work ok without a compensator is that the belt by its nature helps to absorb vibration and drivetrain shocks.
How long does a belt in a belt drive last? Is it something that needs to be replaced regularly? (since there is no apparent way to compensate for belt stretch like there is on a final belt drive)
The gear indicator thing is solved easily IF you also have a Powervision. There is apparently a numerical field that you simply adjust.
Jim G
Jim G
Rivera Primo Gear Ratio Game Changer 1066-0050
It gives you a 1.44/1.36 = 1.06 gearing change (i.e. a 6% change), while retaining the compensator. In fact, it REQUIRES a 2011 or later compensator. The kit includes a new primary chain, a new chain tensioner spacer, and a sprocket that has to be mounted to the compensator.
It's under $200 shipped. Of course, you will need to either provide the labor plus fresh primary lubricant and gasket, or pay a shop. I have no idea what the labor, gasket, and fresh lubricant would total up to.
The 6% change will make a noticeable difference, while raising the rpm at 60 mpg by only a bit more than 100 rpm.
Sounds good!
Can anyone knowledgeable provide a cost estimate for the labor, gasket, and fresh lubricant? (I have no garage to do that sort of even simple mod in)
Jim G
