Valve tick is driving me NUTZ!!
Old May 21, 2014 | 01:51 PM
  #31
Greabert's Avatar
Greabert
Originally Posted by sober1
do yourself a huge favor and give the cats over at Hammer Performance a call (hammerperf.com)- 208-696-1250. I changed cams last season and they cut me a set of fixed length PRs. The cats are extremely knowledge bikers who are very pleasant to deal with. I must of asked 101 dumb-assed questions and they shared their knowledge with me with no attitude. They maybe able to shed some light on your situation.
good luck. I did not want to add an adjustment where the motor already had on, hydraulic lifters. I know everyone does it, right?
anywho, good luck
Good tip and thx, calling now.
Old May 21, 2014 | 05:14 PM
  #32
Greabert's Avatar
Greabert
I just got off with Dan at Hammer Perf and he is one smart dude when it comes to troubleshooting HD engines and he's also about as nice a guy as they come. When I first described my situation his first thought was it was a detonation issue causing the tick, but after he punched in some #'s for the cams, headwork, comp ratio ect he then retracted it and didn't think it was a detonation problem. He knew it would be tough for me to diagnos the tick while under a load without the aid of a dyno so that's one thing I may end up doing. Another messy thing to try would be to run it for a short time after it's hot with the rockers covers removed to see if I could get lucky and hear the problem better with them off if it's up top. He gave me some good tips and glad I called. Thanks for the tip
Old May 21, 2014 | 07:03 PM
  #33
Warp Factor's Avatar
Warp Factor
If it only happens under load, it's probably not valve train related.
How did you determine that there's no exhaust leak?
Old May 21, 2014 | 07:06 PM
  #34
sober1's Avatar
sober1
great, glad you gave him a shot.
BTW, I had an 80" EVO motor that I had installed a Sifton Cam with adjustables and hydraulic lifters and some other speed goodies and as I recall had a tick when I rolled on the throttle. But then again I had a 74" Shovel with cam and adjustable PRs with solids and it ticked like a grandfather clock. My present 96" TC with SE-255s is not dead quiet either. Nothing that concerns me yet, anyhow.
Any possibility noise coming from primary?
Old May 21, 2014 | 09:23 PM
  #35
Greabert's Avatar
Greabert
For one I held a tissue up near the head and throttled it up good and the Kleenex didn't blow around. I also listened near the head with a piece of hose for exh leaks.
Old May 21, 2014 | 09:28 PM
  #36
Greabert's Avatar
Greabert
Not too long ago I pulled the primary and inner primary and put on a 34T front pulley and also a automatic primary chain tensioner and all looked good when I buttoned it up. But while in there I did discover the compensator nut was loose but that made a different noise (rattle) I had heard but fixed.
Old May 25, 2014 | 11:35 AM
  #37
sober1's Avatar
sober1
ny clues/resolution yet?
DRBUICK
Nov 7, 2018 08:40 AM
JimmieJack
Engine Mechanical Topics
17
Dec 11, 2016 02:35 AM
cycojon
Exhaust System Topics
Nov 30, 2011 09:01 PM
Stng72
Sep 6, 2010 09:53 PM
LRS
Aug 24, 2010 04:38 AM
