03 Fatboy Wheel compatibility
Old May 19, 2014 | 06:43 AM
Stickman03's Avatar
Stickman03
Stage I
Default 03 Fatboy Wheel compatibility
I have a set of lace-up wheels from an '02 Heritage. Can they be used as direct fit replacements for the solid disc wheels on my '03 Fatboy? I know the stock rear tire size in '02 was MT90-16. Will a 150-80-16 fit the '02 wheel as that is the stock tire size on my Fatboy? Is the offset the same? Any concerns with pulley or rotor alignment?
Thanks in advance...
Old May 19, 2014 | 08:40 AM
rockinred's Avatar
rockinred
The 03 Fatboy was a year that HD went to a 150 tire. Everything was left the same from the 00-02 models except the wheel on the 03 was machined more to the center/right allowing a 150 rear to fit in the fender without rubbing the belt. So the 02 wheel will bolt up, but once you go to the 150 from the 130 on that it will rub the belt and no room. There will be a ton of room on brake side of fender, but it will rub on belt.
I have no idea why Harley would machine the wheels offset to the belt side so much on the 02 and make it difficult to go wider with tire when you have a bunch of room in fender. Either to offset for primary or to offer an upgrade later? I don't know?
I had an 03 Fatboy and know all the ins and outs as I rebuilt that bike completely. Let me know if you have any other questions on yours.
120hp_softail
Wheels/Tires
Jun 26, 2010 07:09 AM
dhellyer08
Apr 20, 2010 08:01 PM
NYR99JF
Jun 4, 2009 11:42 PM
T4Turtle
May 14, 2008 09:12 AM
stevejt99
Feb 24, 2008 06:37 PM
