Pre 99 front wheel on 06 deluxe
Old May 22, 2014 | 02:11 AM
Scrappy1818's Avatar
Scrappy1818
Default Pre 99 front wheel on 06 deluxe
Has anyone here ever put a pre 1999 front wheel requiring temkin bearings on a newer bike such as a 06 Deluxe. I am thinking about putting a ride wright 21 2.15 on my 06 deluxe. I will be getting the wheel from a friend at a great price, otherwise would just buy the correct one with sealed bearings for my bike. If so how much of a PITA was it? They both have 3/4 in axles so dont think that will be a problem. My other concerns are spacers and brake caliper/rotor. Any help is appreciated.
Old May 22, 2014 | 03:50 PM
Knuckles73's Avatar
Knuckles73
It CAN be done. But I dont think its going to be just a bolt right up kinda job. You may have a problem with the hub being a different size and causing a problem with the 2000 and up rotor vs '99 and older. Although there are adapters to allow using '99 wheels with 2000 and newer calipers.
If the guy is a good friend just yank your current wheel off and see if his will work.... buy him a frosty beverage or 12.
Old May 22, 2014 | 04:28 PM
CouchMaster's Avatar
CouchMaster
It will work rather well - I put '99 Fatboy wheels on my '07 Springer Classic last year. The rotor from the newer wheel does have a slightly larger hole in it but the bolt pattern is the same. The biggest problem is learning to set the bearing end play on the older wheels - this can be researched on the web. I suggest buying some 3/4 inch all-thread to use as an axle and a few 3/4 nuts to snug things up while measuring the movement. Once you do one then the rest is easy.
EzRussSDMC
Dec 21, 2013 02:30 PM
LFTD1
Dec 2, 2011 11:05 AM
cj714
EVO
Dec 21, 2007 09:24 PM
chrome dome dave
Jan 2, 2007 07:27 PM
KBES BAGGER
Nov 5, 2005 07:34 PM
