V&H Straight Shots Slip-Ons
Old Jun 7, 2014 | 06:20 AM
05Fatty's Avatar
05Fatty
Question V&H Straight Shots Slip-Ons
Anybody have tips for getting these things to mount to the support bracket? It's impossible to get my fingers in there to get the nut started on the bolt and I've tried a wrench, pliers etc...with no luck. I've put pipes on several bikes but this 13' FB is a pain!
Starting to really miss my SG.
Old Jun 7, 2014 | 06:46 AM
rbeamj's Avatar
rbeamj
Loosen the bolts on the pipe at the bracket. This will give you some wiggle room. Then you can tighten the nuts to the support plate.
After the support plate is firmly mounted tighten the bolts on the pipe. The front pipe will be a bit tougher but it can be done.
I also used some angled needle nose pliers with good success. Once the nut is started I got an open end wrench on it.
Took a bit of work but I got it done
Old Jun 7, 2014 | 09:53 AM
05Fatty's Avatar
05Fatty
Well, finally got em on. I took the muffler support bracket off and got the front muffler on loose and put that back on. Then I put the rear on and tightened everything down. Still a pain but got it. Thanks.
goldie
2014-2024 Touring Models
May 11, 2018 05:43 PM
Ky Windage
Apr 5, 2009 11:40 AM
up2nogood22
Aug 29, 2008 06:37 AM
Skaarsgard
Mar 5, 2008 08:21 PM
Z_Stingray
Dec 6, 2007 06:08 PM
