Fatboy Sissy bar backrest removal
Old Jun 11, 2014 | 01:42 PM
stv1520's Avatar
stv1520
Default Fatboy Sissy bar backrest removal
Being a NOOB rider, with a 1st time bike, I'm not sure how to do much on it. This is one of my issues. I'd like to take off the backrest portion of my sissy bar. Looks like it would slide right out of the frame, and go right back in when you need it. There are 2 bolts on each side-upper and lower. The upper comes out without any problem. But the lower bolts are right near the fender. If I tried wrenching them out, they could scratch the paint. So I'm kind of at a loss on how to do this! Any suggestions?
Old Jun 11, 2014 | 05:03 PM
sioux565's Avatar
sioux565
You should be able to reach them with an open ended wrench. Just be careful with the paint, like you said. If you aren't comfortable doing so, you can take the side plates off which would require removing the two bolts on each side holding the fender up.
Old Jun 11, 2014 | 05:29 PM
bigblock59's Avatar
bigblock59
Take the sissy bar asssembly off your fender struts first. Then remove it from the side plates like your trying to do.
Old Jun 11, 2014 | 07:51 PM
stv1520's Avatar
stv1520
OK--I'll try that. Thanks guys
Old Jun 11, 2014 | 08:28 PM
toocruisin''s Avatar
toocruisin'
Default btw
Nice Fatboy!
Old Jun 12, 2014 | 07:56 AM
stv1520's Avatar
stv1520
Originally Posted by toocruisin'
Nice Fatboy!
Thanks--But it doesn't hold a candle to yours! That thing is stacked!!!
Old Jun 12, 2014 | 07:57 AM
stv1520's Avatar
stv1520
Are those TORX bolts on the fender???
Old Jun 12, 2014 | 03:24 PM
sioux565's Avatar
sioux565
Yes. A T45 should fit fine.
You will find a lot of random Torx bolts on Harley's.
trainedkilla
May 26, 2020 08:44 AM
Santo
Gear and Other Items For Sale
May 9, 2015 01:34 PM
Yul B. Nekst
Jan 7, 2010 07:15 AM
jtref
Feb 5, 2009 08:00 PM
Kski
May 28, 2008 11:52 AM
