main circuit breaker
Old Jun 13, 2014 | 05:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by olongapo1
Since the breaker and battery are both connected together at a terminal post on the starter the breaker is, by default, part of the starting circuit.
There is no by default... The starter does not draw power through the breaker.
The starter circuit starts at the battery, goes to the solenoid, across the solenoid contacts, then to the starter motor, through the starter case then back to the negative terminal on the battery.
The breaker is not in this path.
Even if the starter motor had a nuclear meltdown and created a dead short to ground, the current would not go through the breaker, it would take the path of least resistance, from battery to starter to ground.
No starter motor circuit draws power through a breaker, no motorcycle, car, lawnmower.
The purpose of the main breaker is to protect the wiring between the main breaker and the input side of the fuse panel, and the wiring between the main breaker and terminal 30 on the start relay.
Since these wires are before the fuse panel, the only thing to protect them is the main breaker.
Old Jun 13, 2014 | 06:46 PM
olongapo1's Avatar
olongapo1
Dan89FLSTC
Your statement "The starter does not draw power through the breaker" is correct.
The breaker is however connected directly to the positive battery cable at the starter terminal therefor amps drawn from the battery, by the starter, are transferred to the breaker. The breaker prevents amps greater than 30 from entering the system when starting the bike. Check the attached schematic. Harley used this electrical design up through 06.
Old Jun 13, 2014 | 08:08 PM
Jackie Paper's Avatar
Jackie Paper
My way of explaining this is the 30 amp main breaker or 40 amp on the newer bikes called a Maxifuse is simple the breaker for the charging system and the starter solenoid. The large contact pulled in by solenoid connects the starter directly to the battery. It has no fuse on the motor itself and pulls close to 160-200 amps. The starter motor in no way pulls thru this breaker. Just the solenoid magnet. In the following attachment, the area that says see wiring diagram includes the start switch, starter relay and 30 or 40 amp breaker and charging system. The 30 or 40 amp also power the fuse box smaller amp fuses. At above idle, (2000 rpm) voltage put out by stator and regulated to 14.8 or so volts forces voltage back to charge battery (12.8 volts)
Old Jun 13, 2014 | 08:32 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC
You obviously do not understand how direct current works.
Old Jun 13, 2014 | 09:42 PM
olongapo1's Avatar
olongapo1
This is my last response on this thread. For those who disagree with me, try this experiment. Remove the regulator wire from the silver terminal of the breaker. Connect an Amp meter to the copper terminal of the breaker. Take a static reading then engage the starter.
Old Jun 14, 2014 | 04:27 AM
FroggyFatBoy's Avatar
FroggyFatBoy
dan and rip are 100% correct..
Old Jun 14, 2014 | 05:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Apologies about the sidetrack Matt....
An easy way to check the breaker would be to do a resistance check across the posts.
But they are cheap...I would replace it.
Sometimes they get weak and will trip at a low amperage, it can drive you crazy trying to find the problem.
Old Jun 16, 2014 | 11:11 PM
Matt K's Avatar
Matt K
I think I found my problem. I went for a ride and found that my voltage regulator plug was out. I was taking my first step and checking the circuit breaker just like you would check a fuse. After all the great responses here, it seems that the 30amp circuit breaker doesn't operate like a fuse and I cannot check it with a simple light test or anything. I'm going to deviate from checking the circuit breaker and like someone mentioned before check the charging system including the stator and regulator.
Old Jun 17, 2014 | 06:05 AM
Jackie Paper
Glad you got it fixed.
Old Apr 28, 2020 | 08:54 PM
Bri’s Corner's Avatar
Bri’s Corner
Stage I
I have power until I turn the ignition switch. When i turn the ignition switch all power shuts down. I then have to wait a while for it to start back. Now, I am not receiving any power to the motorcycle. It has been completely out for a few hours.
Originally Posted by Matt K
I just charged the battery over night and have 12v at the battery, yes
