Samson true duals on Softail... shift rod hitting rear pipe
Old Jun 25, 2015 | 08:59 AM
dusty2221's Avatar
dusty2221
+1 on the pics. My 39s are on the fedex truck for delivery today and I would like to see what you are dealing with
Old Jun 27, 2015 | 06:39 PM
RDY2ROLL's Avatar
RDY2ROLL
Thumbs up
Originally Posted by Transporter
I had the same problem, I loosed every single screw on my left pipe and remove the tail piece. I got a 2x4 and a mallet and gently tap the exhaust forward, needless to say it didn't look like it moved, I tight everything back on, and I was able to gain the 1/4 inch I need it for the shift rod.
Just my experience, there is more wiggle room in that exhaust that it appears, give it a try before you mess with the shift rod.
exactly what I had to do.
Old Aug 16, 2025 | 07:20 PM
Bike_Ghost's Avatar
Bike_Ghost
Stage IV
Originally Posted by Shaylex
I can, and that's the first thing that I'm going to try. I am hoping that between that and maybe having to add a little more bend to the linkage rod, it will give me the clearance I need. I want to avoid pulling the primary if possible.
i know this is a old thread but i am having this same exact issue. How do you add more bend to the shift rod? Thanks.
Old Aug 17, 2025 | 10:32 AM
brapple's Avatar
brapple
I had the same experience with the Cobra true duals, and order the Paughco shift linkage part no.: 10240833 worked perfect.
Old Aug 17, 2025 | 08:22 PM
Bike_Ghost's Avatar
Bike_Ghost
Stage IV
do you have the website for this?
Old Aug 17, 2025 | 08:27 PM
bulldog1776's Avatar
bulldog1776
Did you run this with the bend going over or under the pipe? I've got samson duals on my 97 Heritage and ended up running a bent shift rod over top of the pipe.
Old Aug 17, 2025 | 09:19 PM
brapple's Avatar
brapple
This was ran under the pipe... I order at the following address; https://vtwin.parts/supplier/paughco...t-linkage-718m however it appears this is a special order item.
BennoDeluxe
General Topics/Tech Tips
Jul 29, 2019 08:14 PM
Tailbreaker
EVO
Jan 4, 2014 04:47 PM
phrogflyer
May 17, 2010 08:18 PM
commander112
Apr 2, 2008 09:40 PM
