Anyway to remove rust on exaust?
Old Jun 15, 2014 | 10:55 AM
jeff6898's Avatar
jeff6898
Default Anyway to remove rust on exaust?
I am guessing that the only way to get the rust off of this is to change the exhaust? It is the cross over, y yipe on the exuast.
Old Jun 15, 2014 | 11:59 AM
Uncle G.'s Avatar
Uncle G.
Take a sheet of aluminum foil and a bowl of water. Wad up the aluminum foil, wet it with the water, and use it to scrub off the rust.
Not only will this remove the rust, but the aluminum will tend to fill the pits in the steel, which might help delay the rust from returning.
Old Jun 15, 2014 | 12:08 PM
factorybuilt's Avatar
factorybuilt
Or, SOS pads soaked with water. After you rinse it off and dry it up real good. Finish it up with a coat of "good" chrome/metal polish.
Old Jun 15, 2014 | 12:23 PM
UnknownUser's Avatar
UnknownUser
Navel Jelly?
Old Jun 15, 2014 | 02:43 PM
JimGnitecki's Avatar
JimGnitecki
Turtle Wax chrome cleaner and polish, used with a good scrub pad, will, believe it or not, get that rust off, and then leave a protective layer to help delay re-rusting.
Jim G
Old Jun 15, 2014 | 05:50 PM
mtiberio's Avatar
mtiberio
4 zero (0000) steel wool with simechrome. I use it everywhere I see pits...
Old Jun 15, 2014 | 07:44 PM
Six7One's Avatar
Six7One
This and hit it with polish afterwards.
Old Jun 15, 2014 | 07:50 PM
pat.h's Avatar
pat.h
I 2nd navel jelly, its seriously awsome ****, expensive, 15$ for about 6oz. BUT, it works
Old Jun 15, 2014 | 11:30 PM
oct1949's Avatar
oct1949
you can remove the rust,, but that looks like its through the chrome, if so nothing will bring it back...
Old Jun 16, 2014 | 05:49 AM
HrdNox's Avatar
HrdNox
This is what I was thinking.
