I just bought a replacement shield from our sponser LRS. I un-did all the bolts on the stock windshield, I got the fork mounting brackets off just fine. Here my question - the metal bracket to the lexan, it looks like its glued or taped on and theres no way this is coming off.
* Any ideas?
* ANyone know where I can find the replacement metal for the shield only and ill use the existing brackets
Sounds like a question for LRS. I will be interested in the answer as in time I will replace my shield with one of their tinted recurves. I used their shield on my Electra that I had and was very pleased with it.
* Any ideas?
THANKS!
Those adhesive strips act as a sort of gasket.
When I replaced my H-D quick-detach screen with an LRS replacement, they were attached (like single-faced tape) to the metal brackets but not to the screen - although they may feel like they're "stuck" from having been mashed in place for so long.
They should just peel right off without too much trouble...
Jam436 is correct. I also faced that problem. I took a putty knife and carefully striped that gasket off (most of it peeled off as stated by Jam). I actually reuse it on new windshield since most of it peeled off.
This stuff is actually a double sided tape. I suspect it is just to keep things from rattling. I do know that if it's been on there a few years, it's a bear to get the residue off. I've used heat, solvents, you name it. It just takes a lot of time and effort.
I replaced my stock glass with a Memphis Shades replacement glass after 4 OEM shields in a row cracked at the lower left mounting screw hole. I omitted the adhesive tape with the MS windshield and have had no issues at all.
I bought a flexible spackle knife with a 1inch thick blade at the other HD (Home Depot). I started at the downward iron where it "lips" over the horizonatal iron as I was able to use the lip for a little starter leverage. Just a little bit of muscle and it came off. Surprisingly, the 2 sided tape was still tacky. My 2 words of advice.. You have 2 different size screws and do not torque down the irons until you test fit. I had to give it up last night..
You are correct, install all the screws but don't tighten any down until you've install the windshield. Then once the shield is on, tighten down all the screws you can access. Then remove the shield and tighten the rest downs.
I bought a recurve replacement and was concerned, because it didn't come with new adhesive tape. Admitted, I'm replacing a 10 year old windshield. I took a chisel and slowly, carefully lifted the end of the bracket. The adhsive had aged and came cleanly came off with the bracket.
