Need help with Heritage windshield
Old Jun 27, 2014 | 06:00 PM
Mr.Softy's Avatar
Mr.Softy
I used WD-40 to spray the metal strip as I removed it with a towel wrapped putty blade. Replacing it with a LRS recurve was easier.
Old Jun 27, 2014 | 07:21 PM
Michael knowles's Avatar
Michael knowles
My windshield is a kitty litter tray, free for the taking
Old Jun 28, 2014 | 08:36 AM
mjrfd99's Avatar
mjrfd99
Originally Posted by Bluraven
I used a hot air gun and heated up the bracket and "pealed" it off gently.
I image you could do the same thing with a hairdryer, but it might take tad longer to soften the adhesive.
I then, using "goo-gone" and some light heat, removed the remaining adhesive from the old shield.
+1 Worked great
Old Sep 21, 2014 | 10:33 PM
poser23's Avatar
poser23
Great Thread!! Thanks for all of the comments and suggestions. My LRS re-curve arrives for my Heritage tomorrow. I got the 18" with light tint and with a custom 100th anniversary graphic. Can't wait to see it and try it.
LRS has been great up to this point. James took great care of everything.
Couldn't have asked for more.
Old Sep 22, 2014 | 09:25 AM
Bones77's Avatar
Bones77
Originally Posted by uncle kebo
I just bought a replacement shield from our sponser LRS. I un-did all the bolts on the stock windshield, I got the fork mounting brackets off just fine. Here my question - the metal bracket to the lexan, it looks like its glued or taped on and theres no way this is coming off.
* Any ideas?
* ANyone know where I can find the replacement metal for the shield only and ill use the existing brackets
THANKS!
Not to discount all the methods with glue guns and WD40 and such, but this is easy.
Just flatten the lexan screen out. When it flexes the metal cross bars will pop right off. Takes about a second.
Bones
Old Sep 22, 2014 | 09:37 AM
lemonade_07flstc's Avatar
lemonade_07flstc
I just pulled mine loose when I replaced mine, put 1 small bend in it but got it right out. I had to do it twice since the 16" LRS let way too much wind over and the wife was not happy so had to buy a 20" LRS and put it on and now she is all good. I definately like the look of the light tint also.
I would love to be able find a set of used quick detach brackets so that I can install them on the 16" for when I do ride solo.
Rumba
2018+ Softail Models
May 25, 2019 11:48 AM
gchristopher9
Nov 14, 2017 05:51 PM
harleyheaven
Softail Parts
Apr 22, 2014 06:30 PM
harleyheaven
Apr 21, 2014 11:11 PM
Late Bloomer
Aug 8, 2011 07:12 PM
