where do these Ricors Go??
Old Jun 29, 2014 | 12:03 PM
Knuckles73's Avatar
Knuckles73
Default where do these Ricors Go??
I'm doing a Progressive 1" drop in front with Ricors. Looking at the kit theres 2 springs, one short one long one.
Where does the ricor fit in?
Old Jun 29, 2014 | 12:30 PM
Misbehaven's Avatar
Misbehaven
After you pull your springs out the Ricors's drop in the tubes and then the springs go back in over them.
Old Jun 29, 2014 | 01:06 PM
Knuckles73's Avatar
Knuckles73
dumb ?? I know. Thanks for info
Old Jun 29, 2014 | 01:51 PM
Misbehaven's Avatar
Misbehaven
No problem. Hope you like the new feel of your front suspension.
Old Jun 29, 2014 | 02:06 PM
jreichart's Avatar
jreichart
Any pics of the springs? Some of the progressive kits include a damper spring and main spring. The damper spring goes on the underside of the damper rod, with the larger main spring on the top. The Ricor does go under the main spring.
If this is the kit you have, then the small springs are the damper springs.
If you have the drop in kit, then both springs go above the damper rod.
Old Jun 29, 2014 | 02:19 PM
Knuckles73's Avatar
Knuckles73
I am ordeing the kit Mon. but the pic on Progressive's site ust shows the two shorts and 2 longer ones. Might not be the exact pic. its for a '99 FB front end.
From all the posts it seems they will be a big improvement over the soft stock springs I got now. Having the Shotgun Shock out back really emphasizes the need to improve the front.
mandd71974
Feb 11, 2016 09:51 AM
Bobbed Out
May 18, 2014 05:01 PM
rsking45
Sep 17, 2013 06:58 AM
condition1
Dec 12, 2012 07:40 PM
ynots
May 27, 2012 01:49 AM
