Changing front caliper heritage
Old Jul 13, 2014 | 03:47 PM
97piglt's Avatar
97piglt
5th Gear
Default Changing front caliper heritage
Here's the deal inside pad looks great. Outside pad is completely gone. Down to scraping rotor when turning right. ONLY when turning right. About 4k miles on the set. Is there a problem? If so I will need to change the caliper. Just as cheap to change as put it in the shop to tell me the same thing. How difficult to change a front caliper on 97 heritage. I don't want to upgrade it works just fine with the dual piston set up. Is there a video on changing out a caliper or pretty straight forward. Change it and bleed it.
Any help would be great. You guys never let me down don't start now.
Old Jul 13, 2014 | 03:58 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Rtfm
The caliper is supposed to "float" over the rotor, allowing it to apply pressure from both sides when applying brakes. Check the mounting to make sure. Pretty sure you'll find it bound stationary, allowing pressure from only 1 side. Sounds more like mounting problem, not the caliper itself.
Get yourself a repair manual! It'll pay for itself 100 time over!!
Old Jul 13, 2014 | 04:03 PM
97piglt's Avatar
97piglt
5th Gear
Default Bound stationary.
what am I looking for and how do I fix. Only mounts one way. Definitley not floating. Outside is GONE. Grinding on rotor when turn right.
Old Jul 13, 2014 | 04:16 PM
KumaRide's Avatar
KumaRide
Manual. Google. Either rebuild or replace caliper. The pistons maybe stuck, not releasing inside pad. Pistons should be cleaned every 5k miles. No dust boot so brake dust collects on them and they do not release. Sounds like rotor needs to be replaced also. Inspect rear caliper also!!
ThaGlyde
Aug 25, 2016 08:34 AM
Ozark Joe
EVO
23
Nov 7, 2015 03:40 PM
garrgoyllle
Wheels/Tires
Apr 14, 2013 08:04 AM
SneakyPete
EVO
Sep 11, 2009 04:06 PM
chevdude
Jul 9, 2007 10:25 PM
