Pullback Risers w/stock cables Heritage:
Old Jul 18, 2014 | 02:11 PM
funbikerchick's Avatar
funbikerchick
Default Pullback Risers w/stock cables Heritage:
I want to put some pull back risers on my Heritage. The dealer had a set of 4" with 1 1/2" publlback but told me these would require a longer brake line. I found a set of Baron Kickback risers in the Dennis Kirk catalog that go up 4" and pull back 1 1/2" with the claim that they will work with the original lines and cables. Anyone installed either these or any other pullback riser on a Heritage without changing the cables? I need the bars back a bit, but don't care so much about additional height.
Old Jul 18, 2014 | 03:44 PM
Mr.Softy's Avatar
Mr.Softy
I don't have a heritage but on the Fatboy stock cables work with 4" pullbacks. Were you going to install them yourself?
Old Jul 18, 2014 | 03:48 PM
sioux565's Avatar
sioux565
I see no problem with you going to a 4" riser. I recently went to a 3.5" riser set on my Slim and I could easily have gone to a 4.5" set.
How much slack is there in the brake, throttle, and clutch lines? My biggest thing was getting the stock wiring to stretch out.
sioux565's Avatar
sioux565
Old Jul 18, 2014 | 08:47 PM
funbikerchick
The bars on the Heritage are "higher" than those on other softails, though so I think that could be a difference. I would probably install these myself. I tried to get the dealership to install the one's they had and they said the brake line was too short.
Old Jul 18, 2014 | 09:02 PM
Misbehaven's Avatar
Misbehaven
If your bike is equipped with ABS brakes the you may need a longer upper ABS brake line. But your Clutch,Throttle/Idle cables and wiring should be fine.
Old Jul 18, 2014 | 09:04 PM
funbikerchick
Yeah, it has ABS.
Old Jul 19, 2014 | 07:34 AM
Triple M's Avatar
Triple M
When I had my 2010 Heritage I replaced the stock riser with one from a Deluxe. I don't remember the exact change but it raised them a little and brought them back about an inch. I did not have to change any cables and the Deluxe riser was perfect for me.
FrankEV
Dec 27, 2023 01:44 PM
XKnight
Sep 11, 2013 03:02 PM
oldguyriding
Mar 21, 2013 08:52 PM
Thewaxmania
Oct 21, 2009 01:18 AM
