Is it my Voltage Regulator going out?
Old Aug 16, 2014 | 06:26 AM
Shadowray's Avatar
Shadowray
Default Is it my Voltage Regulator going out?
I have a 2012 Deluxe, battery fully charged when I ride in less than 10 minutes my battery light comes on at the same time my speedo lights go out, my right from turn signal goes out, about 5 minutes later the speedo lights come back... This process repeats itself. My headlight also goes out randomly during this process.
I was told the year of my bike was known for bad regulators but does this sound like that issue?
Any thoughts?
Old Aug 16, 2014 | 06:57 AM
nhrider1's Avatar
nhrider1
Any thoughts?
Yes it sounds like the 2012 Voltage regulator issue. The recall has expired, so you are on your own.
Old Aug 16, 2014 | 07:57 AM
uklauren's Avatar
uklauren
Florida Crew Moderator
Depending when in 2012 you bought your bike you may still be in warranty.
Old Aug 16, 2014 | 08:40 AM
Shadowray's Avatar
Shadowray
Still have a warranty but wanted to see if anyone had this problem
Old Aug 16, 2014 | 09:23 AM
uklauren's Avatar
uklauren
I've had tons of electrical problems with my 12 Heritage. They just put another voltage regulator on last month, even after the recall replacement in 2012. I haven't had a chance to ride the bike much since then, maybe only a couple hundred miles, because it's rained so damn much in the last month but so far I have not had another issue. Mine was also signals, back lights, red warning lights, 6th gear light, etc etc.
Somewhere around there's a post about all my problems with the electrics.
Old Aug 16, 2014 | 09:33 AM
spydyr's Avatar
spydyr
Some 2012 softail voltage regulators are under a recall, depending on your voltage regulator serial number. Yes, it indeed sound like a bad voltage regulator.
Here's a website that describes it: http://www.cyclefish.com/BikerNews/blog/2225/
Old Aug 16, 2014 | 10:23 AM
Shadowray's Avatar
Shadowray
A buddy came by put the tester on the battery was at 14 volts, started the bike it went to about 14.25, within a minute or so it spiked to 17.25 volts and the speedo lights went out etc..
Old Aug 16, 2014 | 12:31 PM
whyrzwaldo's Avatar
whyrzwaldo
Since your voltage is spiking UP to 17v I would say that is most definitely the regulator. My issue is the opposite. Every start my voltage is slow to rise to 14v. CE light stays on until it reaches it but once it gets there it stays. Twice it never rose and stayed at 12v. Trying to decide if it's a VR or battery issue. Anyone ever have this issue before? Not trying to hijack the thread but apologize if it appears that way.
Old Aug 16, 2014 | 12:49 PM
Shadowray's Avatar
Shadowray
No problem...if anyone knows of a better voltage regulator to buy? Or would you go with a new Harley one?
Old Aug 16, 2014 | 05:57 PM
olongapo1's Avatar
olongapo1
"Cycle Electric" specializes in charging systems. Their products are Made in the USA, and are backed with a 3 year warranty. Quality components with prices comparable to HD OEM. Highly recommended. Google them to find their web site.
