Weight on heritage
Old Sep 16, 2014 | 03:20 AM
nanettestrydom's Avatar
nanettestrydom
Stage I
Default Weight on heritage
I need to know if it will be safe to ride with 460 pounds loaded on a Heritage classic? Rider 160 + pillion 240 + leathers and helmet 40 + luggage 22.
According to what I can find on the internet, that might be a little bit to much, but will it still be OK if I do not exceed 70 m/h?
Old Sep 16, 2014 | 04:00 AM
r1cochet's Avatar
r1cochet
The manual for my 2014 says a limit of 399lbs added weight (GVWR 1160lbs - 761lbs running weight).
With a max load, you should adjust the preload on your shocks to the maximum, and ensure your tires are at the proper pressure and are in good condition.
Old Sep 16, 2014 | 04:15 AM
ynots's Avatar
ynots
Heres for the 2013, different years will have a slight variation
o As Shipped 719 lbs. (326 kg)
o In Running Order 752 lbs. (341 kg)
o Gross Vehicle Weight Rating 1160 lbs. (526 kg)
o Gross Axle Weight Rating:
o Front 430 lbs. (195 kg)
o Rear 730 lbs. (331 kg)
Load limit 408
Old Sep 16, 2014 | 07:40 AM
Bluraven's Avatar
Bluraven
Obviously you have a computer so I assume you can look up the spec data yourself so I want repeat that.
I've lost some weight, however a couple of years ago I weighed in at about 265, Wife, 135, tour pak and gear about 30 for a total 430.
The bike handled fine.
Yes when we were all on it, I noticed a difference vs. riding solo, but I don't think the Heritage will have a problem with 460 other than less power.
However if your pillion has 240 on it, it will make a difference in the way the bike handles because that's a high point on the bike.
I think though as long as you are aware of the increased lean ability and are ready for it you shouldn't have a problem.
Old Sep 16, 2014 | 08:35 AM
NDBadlands4-2's Avatar
NDBadlands4-2
The weight limits on bike is conservative from the factory. Still it will effect handling greatly, so take it easy and see where the limits are.
Old Sep 16, 2014 | 11:27 AM
Rick58's Avatar
Rick58
Someone on here in another thread said he had a total of 500 lbs on his Heritage and the bike handled it just fine.
Old Sep 16, 2014 | 12:53 PM
Tx911guy's Avatar
Tx911guy
I weigh 285 and my GF is 160 and we had about 40 pounds of gear in the saddle bags, so we were right at 485 with no issues at all.
Old Sep 17, 2014 | 03:59 AM
oct1949's Avatar
oct1949
I got about 285 also, wife about 125,, always her stuff in the bags,, 8yrs and just turned 50K and mostly 2up riding and Narry had a prob.
I run 36-38 in the front and 40 in the rear. and as said above,, check pressure often...
Will Belden
Oct 4, 2018 06:20 AM
Candubrain
Mar 15, 2018 05:09 AM
Melinsc
Dec 19, 2017 07:47 PM
RHD51
Jul 16, 2017 10:28 AM
UppercaseJC
Feb 5, 2017 08:46 AM
