Engine size?
Old Oct 13, 2014 | 10:23 PM
Luke_2171's Avatar
Luke_2171
Stage I
Default Engine size?
I have a 2008 Sportster Nightster... Whats the largest engine I would be able to put into it?
If there is none, What are your suggestions so I can get more power out of it?
Also, I have a wierd sound when I accelerate. Sounds like a whistle/ styrofoam rubbing against eachother. any ideas?
Old Oct 13, 2014 | 11:25 PM
Zenmervolt's Avatar
Zenmervolt
That depends. How much money do you have? With enough money you could fit pretty much anything into it with the proper custom fabrication and cutting into the frame to stretch it.
If you're asking what's the largest you can go without getting into ridiculous sums of money, that seems to be about 88 CI, though that is still very spendy. Even the 1250 kits aren't cheap, though they're not horribly expensive either.
Head work, cams, and upgraded valve springs to handle the cams, assuming that you've already done the basics like a free-er flowing air cleaner and exhaust, along with a proper EFI tune.
Also, I have a wierd sound when I accelerate. Sounds like a whistle/ styrofoam rubbing against each other. any ideas?
No idea. My instinct would be to check that the belt isn't rubbing somewhere.
Old Oct 15, 2014 | 08:14 AM
grbrown's Avatar
grbrown
Cool
Hi from the UK and welcome to HDF. You need to more clear about what you want of your bike, to better answer your question. Staying with Sportster engines you can readily convert it to 1250cc, which is a popular mod and works very well. While doing that you can consider porting the heads, changing cams and I recommend you check out the Hammer Performance website for more details. Using a proven mix of parts from the likes of Hammer you can get around 100/100 HP/TQ, which is enough for many of us! Bigger than that requires more extensive and expensive mods to the engine.
SadisticMedic
Apr 4, 2024 10:24 AM
TikTok
Aug 18, 2014 01:22 PM
78ironhead
Ironhead
May 11, 2013 06:18 AM
porterjet
Oct 3, 2011 03:12 PM
RyanC
Feb 14, 2010 01:01 PM
