Another Ape / cable question?!?!
Old Dec 3, 2014 | 04:56 PM
Gnarleydudes80's Avatar
Gnarleydudes80
Default Another Ape / cable question?!?!
I've searched, and I don't know if anyone could answer this or not. I just bought a set of stock 72 bars off another forum member to put on my iron 883. Does anyone know if I will need to replace all cables? I have read with other bars in the 10" rise category that you can get away with everything but the brake line, although these bars are wider than lets says a 10" licks z bar. Anyone?? I don't wanna spend 200 for a cable kit, unless I have to.
Old Dec 3, 2014 | 07:05 PM
notofthisworld's Avatar
notofthisworld
Cool
Yes, because they are wider. I put a 7.5 inch new bars on mine, I only had to replace the brake line. However, if they were higher or wider I would have to replace them all.
Good luck bro
Old Dec 4, 2014 | 01:20 AM
harleyglen's Avatar
harleyglen
I put stock mini apes ( 72 bars) on my iron and you only have to change the front brake cable, other cables will reach. The only problem I found is they look too wide at the bottom for the irons so I changed mine to 12" narrow apes and then I had to add some wiring and change clutch cable but still used original throttle cables.
Old Dec 4, 2014 | 06:39 AM
mjptexas's Avatar
mjptexas
6th Gear
Default source for brakelines
I bought a custom length braided stainless steel brake line from these guys:
http://www.helperformance.us
Took a week to get it, high quality. You can specify any length you need. If you are going to go to the trouble of replacing the brake line make sure you get a braided stainless steel one. Marked improvement in brake feel over the stock line.
Old Dec 4, 2014 | 10:40 AM
grbrown's Avatar
grbrown
Thumbs up
Agree entirely, in fact it's a worthwhile upgrade for any bike, stock or modified.
Old Dec 4, 2014 | 11:53 AM
shackdaddy's Avatar
shackdaddy
A lot of guys talk about just bending brake lines and that will make it reach, but i would definately advise you to just buy a new line. With the HD mini Apes and a new line, youre looking at around 150 dollars if you shop around.
Old Dec 4, 2014 | 02:21 PM
Gnarleydudes80
So you didn't have to extend the electrical wiring at all? just the brakeline?
Droid24
May 10, 2018 09:51 AM
Russty__
Sep 20, 2017 09:30 PM
slammed05fatty
Sep 5, 2013 07:40 AM
sickboy949
Aug 14, 2011 09:19 AM
TriggerHappyJack
Feb 1, 2011 01:37 AM
