Nightster shift points
Old Apr 18, 2007 | 08:55 PM
1200nightster's Avatar
1200nightster
Default Nightster shift points
Is it just me or does it seem like 4th runs to 65mph before having to shift to 5th and if you are in 5th between 60 and 65mph it vibrates hard. The same with 4th between 50 and 55mph. let me know maybe I have a problem.
Old Apr 18, 2007 | 09:39 PM
Bagpiper49's Avatar
Bagpiper49
Default RE: Nightster shift points
2007 1200 C has similar tendencies. usually shift to 2nd about 20 3rd 30 fourth 45-50 and fifth smooths out around 70. Havent been on the highway yet and am not in a hurry to do so. Just feel good about riding 45-65 especially with the high winds we have been having. Wish someone with a tach could tell us what rpms we are hitting in diferant gears.
Old Apr 19, 2007 | 02:43 AM
FIA289Cobra's Avatar
FIA289Cobra
I have atach in the process ofbeing added to my nightster. I'll be able to chime in at a later point.
Old Apr 19, 2007 | 05:43 AM
1200c's Avatar
1200c
No problem. Sportsters are geared tall and you don't want to put it in fifth gear until 65 mph. Don't shift as much and rev her higher and both of you will be happier.
Old Apr 20, 2007 | 05:53 PM
vtman68's Avatar
vtman68
6th Gear
I'm getting some really strange vibrations from my nightser. Same thing, 4th gear between 50-60. Whats that all about?
Old Apr 20, 2007 | 05:59 PM
Ballsack's Avatar
Ballsack
ORIGINAL: vtman68
I haven't noticed anything on mine aside from the normal sputtering.
Old Apr 20, 2007 | 06:27 PM
MacAttack's Avatar
MacAttack
In top gear at 70 my tach reads 3400. 70 is a sweet spot.
Old Apr 20, 2007 | 09:47 PM
Ex11b's Avatar
Ex11b
ive noticed the same thing with my nightster.
i was starting to think i had a loose motor mount, now im leaning towards it being a rubber mounted engine.
put it in nuetral, on the jiffy stand, and stand beside it and work the throttle. my engine shakes independent from the frame.
also while engine off, i can move my engine with my hand.
is this normal with rubber mounted v-twin?
AmericanNightster
Jun 24, 2010 05:58 PM
flat4fan
Dec 10, 2009 12:14 PM
hogsolo
Aug 25, 2008 03:33 PM
blackie
Jan 2, 2008 11:12 AM
Nightster 13
Jul 10, 2007 10:57 AM
