DONT HAVE A TACH SO WHEN DO I SHIFT???
Old May 25, 2007 | 01:01 PM
blackie's Avatar
blackie
Default DONT HAVE A TACH SO WHEN DO I SHIFT???
My nightster does not have a tach at the moment, at what speed do i redline in first, and in second, ect..... i know when to shift when driving normal but when i want to haul *** i just wanted to know my rpm limits according to my mph/gear. thanks
Old May 25, 2007 | 01:04 PM
jalopy's Avatar
jalopy
Default RE: DONT HAVE A TACH SO WHEN DO I SHIFT???
Shift when you hit the rev limiter.
Old May 25, 2007 | 01:25 PM
StargazerXT12's Avatar
StargazerXT12
ORIGINAL: jalopy
Could you explain this? Thanks.
Old May 25, 2007 | 01:38 PM
mejonesrebel's Avatar
mejonesrebel
when it goes nuh nuh nuh and won't go any higher, you are on the rev limiter
and shift
use the force luke
I think there is a thread in here about that already
Old May 25, 2007 | 01:45 PM
SportyPig's Avatar
SportyPig
The bikes have a rev limiter incorporated into the electronic ignition. When you reach the rpm level that would be red line, it sputters and won't rev any higher. I've only hit it once on my bike. And that was because I was trying to make noise more than riding fast.
You will get more performance from the bike if you shift before that point. You will be out of the power curve before you hit the rev limiter.
dsuppa's Avatar
dsuppa
Do not hit the rev limiter everytime, that would not be a good idea.
Just shift when it sounds like the engine is working really hard to keep up with road speed.
Old May 25, 2007 | 02:17 PM
dingo's Avatar
dingo
3rd Gear
if your asking this question you need to ride more. you'll figure this out with a few more miles.
WVHogRider's Avatar
WVHogRider
ORIGINAL: jalopy
[sm=funnypostabove.gif] And you beat me to it Jalopy.
I don't have a tach either, so do as mejonesrebel stated and just "use the force Luke".
Old May 25, 2007 | 02:37 PM
whaap's Avatar
whaap
Read your owners manual. It will tell you what speeds to shift at when riding in a normal fashion.
Old May 25, 2007 | 02:41 PM
pwnzilla's Avatar
pwnzilla
you'll hear the engine start to wind out and the engine will vibrate more more etc. as stated above shift when it sounds and feels like the engine is working too hard for the gear.
