Which Top Motor Mount??
Old Feb 3, 2015 | 10:44 PM
ibmikexxx's Avatar
ibmikexxx
3rd Gear
Default Which Top Motor Mount??
I'm putting an 02 carb'd 883 motor in a Kraft tech hardtail frame and need help with a top motor mount. The stock one doesn't work and I was advised on a universal mount that would obviously adjust. Seems easier said than done. It's my first build and I'm having trouble settling on one that will work with minimal fabrication...preferably none.
Old Feb 4, 2015 | 03:59 AM
mreed's Avatar
mreed
Top front or the top middle?
If you have a top front mount you don't need a top middle mount. I don't know of an adjustable mount.
If you feel like you must have one they're simple to make. Cut your stock one down leaving just the head strap so you can retain your choke cable holder. Cut a plate to fit the mount provision on the frame itself. Bolt that piece to the frame then all that is left is connecting that plate to your headstrap. You can get creative there.
Old Feb 4, 2015 | 05:42 AM
grbrown's Avatar
grbrown
How about asking the frame maker? If they don't offer one then as you are building a custom you may have to make a custom part!
mang0
Aug 3, 2016 11:26 AM
apetterez
Apr 1, 2015 06:45 AM
the_game
Jun 16, 2014 03:55 PM
McMurphy
Jul 24, 2013 08:23 AM
wapatooie
May 31, 2008 09:07 AM
