Front motor mount collapsed
Old Jun 14, 2014 | 07:40 PM
the_game's Avatar
the_game
6th Gear
Default Front motor mount collapsed
Found the front motor mount on my 2003 ultra is collapsed. I don't have any vibration issues, I just noticied the center bolt through the mount was loose.
Is there any issue with riding the bike before I get this fixed? could I end up doing damage to something else if I don't change the rubber mount sooner than later?
Old Jun 14, 2014 | 10:44 PM
Fishrrman's Avatar
Fishrrman
I wouldn't ride it until it's repaired.
You don't want the motor bouncing around in the frame without the mounting system "whole" with which to "contain" it...
Old Jun 15, 2014 | 04:17 AM
4_stroke's Avatar
4_stroke
The front mount bolt goes through a tube in the mount. At the bottom there is a large washer. The whole thing is failsafe if the bolt is tight. Are you sure the mount has actualy failed or is the bolt just lose? A colapsed mount will not result in a lose bolt.
Old Jun 15, 2014 | 06:23 AM
grbrown's Avatar
grbrown
Talking
I wouldn't ride far. Having failed it isn't performing its function of isolating the engine from the frame. You should be able to get one from your local dealer Monday morning and install it over lunch.....
Old Jun 15, 2014 | 09:31 AM
the_game's Avatar
the_game
6th Gear
The rubber isn't torn but it looks collapsed to me. I will compare to another bike to make sure. It wasn't vibrating with the bolt loose and it isn't now that I tightened it.
It doesn't look too hard to replace.
Old Jun 16, 2014 | 02:25 AM
4_stroke's Avatar
4_stroke
If the rubber is at least 1/2inch thick it should Ok. Depending which one you have the can look to "bulge". This is what a wrecked early type one looks like
Old Jun 16, 2014 | 10:42 AM
freedub2003's Avatar
freedub2003
I just replaced mine with a Dag Specialties model, that is supposedly like the early model mounts. It is much smoother now, and only set me back $20 compared to $70ish at the dealer.
Old Jun 16, 2014 | 02:42 PM
103 sedona orange's Avatar
103 sedona orange
Replace the mount, it's a easy job.
Old Jun 16, 2014 | 03:55 PM
TO34's Avatar
TO34
Easy but messy job, just did mine turned out the mount was installed upside down. Flipped it over & bike is crazy smooth now, CD never skips!
Take your time & read this
http://www.moccsplace.com/images/mount/mount.htm
cajun1957a
Mar 3, 2017 03:19 PM
TWIN CAM 96
Apr 15, 2011 03:38 PM
harleybob
Aug 21, 2008 12:14 PM
Rrroberts
Jul 1, 2008 03:39 PM
Johng434
May 5, 2006 09:24 PM
