Ceramic headlight connectors
Old Feb 10, 2015 | 09:42 AM
bigmant's Avatar
bigmant
Default Ceramic headlight connectors
Hey gang,
My headlight melted again, this is now the second time so I'm looking at a permanent fix. I know some people here have used some ceramic sockets to solve the problem, but also a better relay to run a high wattage bulb? I figure while I'm in there I might as well go bigger lol.
Can someone send me a link to an eBay listing or something for the parts I need? I don't want to order up the wrong stuff. Thanks!
Kevin
Old Feb 10, 2015 | 11:21 AM
blackSP's Avatar
blackSP
I think you need to fix the root cause, not apply a patch to avoid more problems...
Old Feb 10, 2015 | 11:28 AM
grbrown's Avatar
grbrown
What wattage bulb are you using? Does the wiring to the bulb holder hold up OK?
Old Feb 10, 2015 | 01:12 PM
mrfikser's Avatar
mrfikser
I can't answer you inquiry..But if you are running a higher wattage bulb you are drawing more current so you might want to pull a larger size wire along with that relay replacement ..part of the issue with the lamp plug may be that the wires are too small and with the current increase causing the voltage to drop, which in turn causes a even greater current draw...
Old Feb 10, 2015 | 02:37 PM
bigmant's Avatar
bigmant
I'm using the stock harley bulb, whatever that happens to be. Wiring looks fine, it's the holder that's melted.
Old Feb 10, 2015 | 05:54 PM
Mick's Avatar
Mick
http://www.cycleterminal.com/headlight-kits.html
Just select ceramic before you order.
This guy fabs up some nice stuff also.
http://easternbeaver.com/Main/Wiring...s/h4_kits.html
You might just check to see if your stock female terminals are good and tight , loose can cause heat buildup.
Either way , even a stock bulb will be brighter and the handlebar switch will last forever because of the reduced amp draw.
Mick
Old Feb 10, 2015 | 08:24 PM
Von_Zipper's Avatar
Von_Zipper
Do a search for CREE H4/9003 1PC LED 30W on eBay.
Old Feb 10, 2015 | 11:04 PM
bigmant's Avatar
bigmant
That looks promising! Have you used it before?
Old Feb 10, 2015 | 11:08 PM
bigmant's Avatar
bigmant
Mick
Seems kind of pricey, but if it works it works! Have you used either one personally or have just heard they are good?
Old Feb 11, 2015 | 06:42 AM
grbrown's Avatar
grbrown
I'm also cautious about modern technology, where replacement headlamp bulbs are concerned! I installed a factory HID kit in my Glide, excited by the promise of super lights, which my car at the time had from new. I replaced it after a while because while it was great during daytime, it was awful at night! There are so many HID and LED options available at present I wait to be convinced that any one of them is actually worthwhile.
