shock adjustment
Old Apr 21, 2007 | 01:18 AM
DustMan's Avatar
DustMan
6th Gear
Default shock adjustment
can anyone tell me how to adjust my rear shocks on a 2000 sporster xl1200
[IMG]local://upfiles/29212/DF9DFA3B334D4ABDB914562BA35ADAF0.jpg[/IMG]
Old May 5, 2007 | 01:49 AM
1stTimeHD's Avatar
1stTimeHD
Default RE: shock adjustment
i think most shocks are adjustable with a special wrench where u actually turn the notched part of the shock on the bottom to different heights
Old May 5, 2007 | 03:19 AM
XL1200C/C's Avatar
XL1200C/C
6th Gear
You gotta buy the wrench. When I got my bike new, the shocks were at the lowest setting, and I bottomed out on the way home. I tried to buy the wrench the next day, and they said they only had one, and that they needed it back. He let me take it with me, and when I came back with it, I gave him two more I made at work. As long as you have a pattern, it's simple. Put the shocks at the highest level, mineare at five, and you should be fine for any load.
Safe Riding!
Old May 5, 2007 | 08:48 AM
hillbillyonahawg's Avatar
hillbillyonahawg
The wrench you want is very similar to a spanner wrench.It is a very simple designed tool.I bought my shortly after I bought my bike.The one I got wasn't but about 9 or10 bucks.
Old May 31, 2007 | 06:36 PM
1stTimeHD's Avatar
1stTimeHD
Could you tell me which way to turn them to get a stiffer ride so it does not bottom out is it clockwise or cc clockwise?
Old May 31, 2007 | 06:55 PM
ride2tires's Avatar
ride2tires
turn the shock clockwise....
that is to say to the 'Lower" notch. the lower the notch, the more compression on the spring. the more compression, the stiffer the ride.
Old Jun 1, 2007 | 12:54 AM
1stTimeHD's Avatar
1stTimeHD
Hey thanks for the info
Old Jun 1, 2007 | 01:08 PM
WVHogRider's Avatar
WVHogRider
I used a pair of channel locks with rubber caps over the teeth to adjust the shocks on my '00 Sporty. I know some of you may cringe (sp?) at that thought. But it worked, it didn't marr the finish, and I didn't buy the wrench. I actually just used the same procedure last week on the front shocks on myfourwheeler.
sbeamer
2014-2024 Touring Models
Jan 19, 2015 07:02 PM
davbib
Jul 8, 2013 12:21 PM
antman27
Aug 24, 2009 09:09 AM
medic434
Jul 12, 2007 03:34 PM
supermario
Feb 20, 2007 06:01 PM
