Tank Swap
Old Mar 11, 2015 | 10:32 PM
T.D.Teel's Avatar
T.D.Teel
3rd Gear
Default Tank Swap
Got a 2008 nightster 1200 lookin for more fuel read a 2010 streetbob tank will fit but will I half to change fuel pumps cable connectors pigtails etc.?
Old Mar 11, 2015 | 11:32 PM
Ployd4's Avatar
Ployd4
I wouldn't think so. But usually when you buy a tank it doesn't come with the pump. You'll probably have to keep your old one and put it in the new tank. But I can't tell you if the street bob tank will fit. Seems to me that is a pretty big tank. Might effect your seat. How many gallons is the tank? I put a 3.3 tank on mine and I can easily go 120 miles. Light comes on around 80 around town.
Old Mar 12, 2015 | 12:02 AM
TheMakani's Avatar
TheMakani
if I'm not mistaken, the nightster tank is 3.3gal. the street bob tank is 4.7gal. sportster customs have a 4.5gal tank
might be best to look for one of those. is .2gal worth the challenge?
Old Mar 12, 2015 | 12:44 AM
T.D.Teel's Avatar
T.D.Teel
3rd Gear
Ya my nightster tank is 3.3 only reason for that .2 gal increase for the bob tank is I like the lightweight and manuverability of my sporty but like the look of the dyna tanks
Old Mar 12, 2015 | 12:46 AM
T.D.Teel's Avatar
T.D.Teel
3rd Gear
Plus I like a challenge doin stuff people said caint be done which it can I've seen the dyna tank on a sporty on another forum looks clean but he didn't get into pumps and stuff
Old Mar 12, 2015 | 12:47 AM
T.D.Teel's Avatar
T.D.Teel
3rd Gear
Old Mar 12, 2015 | 12:19 PM
Thingfish's Avatar
Thingfish
Well, you said you like a challenge. Has been done plenty of times in the past and used to be a common mod up through the Evo years, but it will likely not be plug and play. You will need a pump for starters. May also need to reshape or significantly shim the frame channel. As mentioned it may easily conflict with your seat mount and thriple tree clearance turning the bars. Honestly, I like fatbob gas tanks, but proportionally they look a little off on a Sportster to me personally. You can always have something fabbed up to fit too.
Old Mar 12, 2015 | 12:25 PM
Thingfish's Avatar
Thingfish
Here's a link to someone's build...
http://www.harley-davidsonforums.com...k-mounted.html
Old Mar 12, 2015 | 12:58 PM
grbrown's Avatar
grbrown
The pump etc inside a big twin tank aren't the same as they are for a Sporty. They may well work fine, but certainly the safest bet is so go with a 4.5 gallon Sporty tank, unless you want to do a bit of experimenting!
Old Mar 12, 2015 | 02:08 PM
T.D.Teel's Avatar
T.D.Teel
3rd Gear
If the pumps are different wouldn't the cfm be different as well and do y'all think that would be a issue?
NorCalCruiser
Nov 22, 2021 02:02 PM
firefighterhoke
2018+ Softail Models
Mar 11, 2020 08:26 PM
ib5150
Jan 12, 2013 08:35 PM
ivel_86
Oct 27, 2012 04:44 AM
elvis8310
Apr 1, 2009 09:28 AM
