Burly cable problem!!!!!
Old Apr 15, 2015 | 08:06 PM
spacewok71's Avatar
spacewok71
6th Gear
Default Burly cable problem!!!!!
I am having a problem with a set of cables I received with the 14" narrow bottom apes for my 2009 1200 Custom everything else was fine but, the throttle and idle cables don"t fit in the switch housing where the stock cables go. Has anyone else had this problem? If so, what did you do to fix it?
Old Apr 15, 2015 | 08:17 PM
Iarecobra's Avatar
Iarecobra
My burly kit fit perfect on my 1998. I know they gotta "pop" in. Perhaps each one is a diffrent size. Try switching them around.
Old Apr 15, 2015 | 08:29 PM
spacewok71's Avatar
spacewok71
6th Gear
Yeah I tried the Iarecobra, put WD-40 on the end and nothing I don't wanna force it in and damage the switch housing or the throttle cable, the idle cable has about 1/8-1/4 in wiggle room.
Old Apr 15, 2015 | 10:22 PM
Iarecobra's Avatar
Iarecobra
If it were me I'd contact burly. Make sure you have the right kit. Or the right cables.
Mine popped in pretty easy.
Old Apr 16, 2015 | 12:35 PM
nashvegasmatt's Avatar
nashvegasmatt
Mine were a little finicky which is why I put the stockies back on since they had enough length for 14" bars
Old Apr 16, 2015 | 03:07 PM
Sw1's Avatar
Sw1
Mine worked fine on my 2014. Where are they not fitting? do you mean clicking into the housing? or the actual cables are too fat? I reused the brass keepers on mine. but everything buttoned up perfect.
Old Apr 16, 2015 | 03:51 PM
hardwick48's Avatar
hardwick48
Default cables
Try switching them around. Each one goes in a certain place. Maybe you got them backwards.
Old Apr 16, 2015 | 09:08 PM
spacewok71's Avatar
spacewok71
6th Gear
I spoke to the people at Burly and they told me to interchange them but, they can't due to the throttle fitting being bigger than the diameter hole in the switch housing where it goes so, I switched the wires at the carb and now it works the way it's supposed to but I can't get it adjusted to where the throttle doesn't stick.
Old Apr 16, 2015 | 11:36 PM
Iarecobra's Avatar
Iarecobra
Make sure your grips isn't pushed too far onto the bars. Move the entire housing about 1/8 of an inch to the right (when sitting on the bike) see if they snap back like that.
Old Apr 20, 2015 | 06:31 PM
spacewok71's Avatar
spacewok71
6th Gear
Thanks for the help with my cables everyone.. I had the cables the way they were when I disconnected them at the carb. so I figured that's the only way to install them but its good now. Thanks again for your help..
dylan199
Mar 29, 2025 09:28 PM
86evokid
EVO
May 7, 2019 03:00 PM
Mikew90
EVO
Apr 1, 2018 08:47 PM
natural gasser
EVO
May 7, 2017 07:01 PM
WillyD
Jan 14, 2014 03:40 PM
