V&H slipons
K&N Filter
No fuel management module
New fuel filter installed, clean air intake, new plugs, seafoam put through it,
argh.
Based on what I found in research I would try the CPS first. If you have tried all of the other basics. That is a quick and cheap fix, at least on my sportster it would have been. The only other thing I was going to check on mine would be pin holes in the fuel lines in the gas tank. I was told that it happens and the loss of pressure could cause the stuttering issue. That would have been the last thing I checked.
Thanks.. Yeah the lines are good. I've also been reading a bit about the CPS.
Bike is going on the scanner right away.. Will see what that says. ...
