Spark plugs - changed how often?
Old May 20, 2015 | 01:39 PM
autobite's Avatar
autobite
on the spark plug topic, I went for a ride earlier in the season and all of a sudden my bike started sputtering and felt like it was going to die. I had to keep the thottle on in order for the bike not to die so I could pull off on the shoulder. Looked on the bike and noticed the plug was off of the spark plug. I've been reading around and looks like this is a common issue? I did a coil relocation and thought my leg bumped the plug off.
Recently, after a bit of riding, the bike sputters on 2nd gear and the check engine light goes on and off. I have to ease off of the throttle and its back to normal. could this be a result of a bad spark plug from the first incident ? I have a 2014 48 and have owned it for a year with about 3200 miles on it.
Old May 20, 2015 | 02:55 PM
rasmith3530's Avatar
rasmith3530
1st Gear
Originally Posted by Scuba10jdl
NGK DCPR7E for a stock Evo Sportster.
Is that NGK part number applicable for both carbureted and FI Sporty models, and both 883 and 1200 engine sizes? Just curious. Mine is a 2000 883, with the C/V carb. Thanks.
Old May 21, 2015 | 09:36 AM
Kenny94945's Avatar
Kenny94945
Check gap and clean the side electrode (wire brush) every 5K miles.
I leave the porcelain and center electrode alone.
Add a little anti seize to the plug threads and die electric grease to inner rubber plug cap/ boot.
OK to torque plugs at 12 lbs
In a stock F1 engines plugs tend to look good with no gap wear at 10K mileage.
Service manual says replace at 20K.
Cost is about $3 a plug.
Your call when to replace.
hdwd2000
May 25, 2017 08:37 AM
2013superglideseattle
Jun 21, 2015 12:37 PM
HogNewbie
Sep 18, 2009 08:03 PM
emtjayb
Dec 27, 2008 11:10 AM
cwalms
May 19, 2008 12:35 PM
