Front end squeaks over bumps.
Old May 28, 2015 | 04:52 PM
98INFINITY's Avatar
98INFINITY
Default Front end squeaks over bumps.
I have a 09 XL, iron. Front end squeaks when going over moderate bumps in the road. Anyone have any idea what it could be? I've ruled out the tank lift so far and the rest kinda goes above my ability. Thanks!
Old May 28, 2015 | 05:07 PM
ivanford's Avatar
ivanford
Is it possibly the springs inside the fork tubes, mine squeaks a little, but you only hear it when the bike isn't going.
Old May 28, 2015 | 05:15 PM
HOTLAP's Avatar
HOTLAP
Try using tape or bungies to temporarily relocate all cables & hoses (clutch, throttle, brake) and take it for a run, that will at least eliminate those if it's still squeaking.
Old May 28, 2015 | 09:26 PM
franktko's Avatar
franktko
Can you replicate the squeak if you hold the front break and just push on the bike while it's not running?
Old May 29, 2015 | 12:55 AM
98INFINITY's Avatar
98INFINITY
Tried the hold the front break and work the front end, doesn't squeak at all.
Old May 29, 2015 | 09:43 AM
Kenny94945's Avatar
Kenny94945
Well, squeak implies rubber or dry metal to metal.
Are you sure it is the front end?
You tried bouncing to no effect so OK.
Maybe it is flex.
Lube and retorque front axle. Retorque triple clamp bolts.
Check front fender and headlight mounting and eyebrow.
I'd be surprised if the brake components had anything to do with this, but look them over anyway.
There's not much on the front end to check.
Other areas check rear swing arm attaching bolts...these do come loose.
Check motor mounts.
Other guesses - check seat, check battery, rear fender for looseness.
Good hunting.
Old May 30, 2015 | 06:21 PM
98INFINITY's Avatar
98INFINITY
Was the head bolt...was super loose! Scary.
Old May 30, 2015 | 06:25 PM
franktko's Avatar
franktko
That squeak could've turn into a *clunk*!!
cmosentine
Mar 12, 2013 09:10 PM
hillclimber
Oct 17, 2010 11:25 PM
oinker02
Feb 6, 2009 08:22 PM
20LowRider02
Mar 9, 2008 12:40 AM
UltraBrian
Dec 29, 2006 12:59 AM
