Just curious as to how many out there use the kill switch or the key to shut down and why? i reach forward on my 99 1200c to shut down with the key it is just the way i have always done it... a friend advised me to use the kill switch first. what say you?
I use the key. If I use the kill switch I may forget to take the key out. The kill switch was designed for emergency shut down. And I imagine its on there because of federal regulation.
I hit the kill switch then turn the ignition off to turn off the lights too.
The problem with just turning off the ignition
Most people park it in gear
If the start button shorts (hey **** happens) and the run switch (kill switch) is on the bike moves unexpectedly.
I have the security jawn with the keyless fob. So the only way to turn the bike off is with the kill switch and that was from the manufacturer for whatever that is worth to you.
I use the kill switch, then turn off they key. I was told from a Harley dealer mechanic (take it for what it's worth) to use the kill switch because it tells the ECM to turn off the motor as opposed to just shutting off the power to the ECM which in turn kills the motor.
I use the kill switch so if I have a problem while I'm riding, like the throttle sticking, I hit that instinctively instead of having to reach for the ignition.
