Stripped primary case
Old Jul 19, 2015 | 04:23 PM
Drangus's Avatar
Drangus
Stage II
Default Stripped primary case
Okay guys here's a good one for you..Im in the process of swapping out both cam and primary cover. Started on the cam side, snapped a bolt and decided to move to the primary side. Much simpler until I got to the last bolt, was torquing it down to 7 pounds after working up from 3 pounds, and I heard a loud pop. Thought I snapped the bolt, but nope. Pulled the cover back off and it stripped the inside of the actual primary case somehow. So now what in the hell do I do? The bolt will go in and torque down to maybe 2 pounds before it just spins. So now I have no idea what to do. Could I get a bolt that's like maybe 3/16 longer to thread through?
Old Jul 19, 2015 | 04:43 PM
Cool Inferno's Avatar
Cool Inferno
Get a new good torque wrench quick. It should have been okay to about 120 inch pounds (not foot pounds).
Old Jul 19, 2015 | 05:23 PM
Drangus's Avatar
Drangus
Stage II
The wrench is fine, it's the actually primary case that stripped out.
Old Jul 20, 2015 | 09:42 AM
John Harper's Avatar
John Harper
Helicoil, Time Sert (?) or any other decent thread repair technology.
John
Old Jul 20, 2015 | 11:32 PM
JustOneDean's Avatar
JustOneDean
He's saying that may have been caused by a miscalibrated torque wrench.
Timesert would be the way to go. A longer bolt will just punch through the case if you try to torque it down, which will give you a much bigger and more expensive headache.
poczatek
Ironhead
Apr 10, 2017 05:02 PM
lkr0
May 6, 2014 09:24 PM
Syris71
Aug 26, 2012 07:08 PM
parakiller
Apr 27, 2009 10:33 PM
blackfinbob
Aug 1, 2006 10:33 PM
