Bike turned itself off and will not turn back on.
Old Aug 23, 2015 | 10:13 PM
JohnnyC's Avatar
JohnnyC
When you replace the stator buy the upgrade kit and that will give you 32 amp capacity. The kit includes a 32 amp regulator, a 32 amp stator and the matching rotor.
I upgraded using Cycle Electric components. My first replacement HD Stator fried in 5k miles. Cycle Electric uses a sturdier coil winding in the stator that is able to withstand higher temps and provide higher output at lower revs. Their regulator is sturdier and controls voltage with an improved design.
Old Aug 23, 2015 | 10:33 PM
blackhatguy's Avatar
blackhatguy
I had already replaced the stator, accel 23 amp. I had originally used a cycle electric regulator but failed to replace the bad battery, so it killed the regulator. Then, I replaced the battery and the regulator, but with the stock replacement that is made for the 18 amp and now we find it is not catching all the power, overcharging the battery
Old Aug 24, 2015 | 06:17 AM
JohnnyC's Avatar
JohnnyC
18 amp regulator with a stator rated 23 amps (23 really?) seems mismatched. Most likely passing unregulated AC to the battery, which is of course DC.
There are many advantages to using a higher rated system but it must include the rotor too.
Best of luck straightening it all out.
Old Aug 24, 2015 | 06:41 AM
cHarley's Avatar
cHarley
How old is this bike? This thread contains no info about the bike, like year, miles, etc.
Old Aug 24, 2015 | 07:52 AM
blackhatguy
94 1200 sportster. And yes, it was a mismatch. When you are broke down in the middle of nowhere north Dakota and working 7-12s you get what they got in stock so you can get back on the road. When the "correct" one burned out, the factory replacement at 18 amp was all that little town had in stock. So, I ran with it and since then it has killed two batteries and countless turn signal lights from over-voltage. Got the good **** on the way though now, New battery and correct regulator at the same time. Really, that has been my problem. At one point, I have had the correct part in each position but never at the same time lol
Old Aug 24, 2015 | 09:22 AM
cHarley's Avatar
cHarley
That makes sense. You could run the higher (23) amp regulator with a lower amp stator in an pinch, but not the other way around without blowing something up eventually.
Old Aug 24, 2015 | 08:52 PM
traffic jam's Avatar
traffic jam
My 95 sportster would die randomly. The key was also loose in the ignition. It was the ignition switch. This is quite common on older sportsters. If the battery and connections are fine, take a look at the ignition switch.
Kettenhund75
Feb 17, 2021 02:38 PM
Luckyeight
Electrical/Lighting/Alarm
Mar 4, 2019 03:10 PM
Haus1904
Jun 20, 2018 11:10 AM
mac1313
Feb 4, 2013 12:58 PM
popcorn13
Nov 12, 2012 05:04 PM
