Thunder Torque Inserts
Old Aug 28, 2015 | 03:44 PM
Simon Lam's Avatar
Simon Lam
Default Thunder Torque Inserts
Just curious which model works for the Big Radius V&H for the SPortster?
I currently have the hardkore baffles but I had to really break it in to get it to fit. They seem okay for now but I want that low deep tone that I see the the DK custom videos.
Any help would be appreciated.
Old Aug 28, 2015 | 04:11 PM
hscic's Avatar
hscic
It depends on the diameter of your pipes and your baffle size. DK's website has a full page on fitment including pics. You only have 3 to choose from and the 118 is probably to small. I have 3" pipes and 2" baffles and the 258's were a tad to big and the 158 were too small. if in doubt, PM Kevin or email support@dkcustomproducts.com and ask them. They are awesome in responding.
Old Aug 28, 2015 | 04:44 PM
Simon Lam's Avatar
Simon Lam
Okay thanks. It would be great to see customer reviews on it for the big radius..so I know if I need to do anything to them like shave it down to install them.
Thanks Hscic
Old Aug 28, 2015 | 05:20 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Depending on the size of your baffle holes, either the W118 or the W158. You can see the guidelines HERE.
It's a matter of drilling a hole, and if you want to fit the nut between the pipe and the heat shield, they you will need to get some jam nuts and cut down the studs a little.
Most just drill thru the heat shields and pipes, then use the hardware as it comes.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
dortiz
Oct 5, 2011 04:47 PM
welder
Sep 4, 2010 06:25 PM
mcdaniel52761
Mar 21, 2009 10:27 PM
jghiselli
Exhaust System Topics
Feb 13, 2008 01:20 PM
joey20
Aug 14, 2007 03:15 PM
