Better still to buy the H-D belt tension tool, which takes all the guesswork out of it. If you are a body builder and weigh 300 pounds, your twist of a belt is likely to be rather more than one of our 100 pound lady members will be able to manage!
Motion Pro do the same type tool as Harley but its $$$ cheaper. This video gives a good explanation of the deflection required but I don't know if there is nay difference between models?
The proper way to check the belt is deflection at 10 lbs force.
I use the Harley tool , I purchased it 2 Harleys ago.
I noticed when I went from stock 11" rear shocks to 13" rear shocks , I had to set the deflection the same as a Roadster.
The short shock bikes never get to full extension of the rear arm , as they never get past straight.
This occurs when the center line of the front sprocket , the swingarm pivot , and the rear sprocket actually align.
I noticed the belt got too tight as it got warm (sprockets both expand from heat).
A couple thousanths at each sprocket equates to a pretty big change in tension at the center of the belt.
To be on the safe side , check deflection again after running 60 miles or so , mine checked too tight at 60 miles.
Setting it at the looser Roadster spec took care of this.
Just something my **** self came across.
Mick
