STAGE ONE question by new guy
Old May 5, 2007 | 01:31 PM
Buda's Avatar
Buda
Default STAGE ONE question by new guy
I just purchased my first HD bike 04 1200R. It already had screamin eagles put on it by the previouse owner and jetted (so the dealer says). My question is since it has the factory air cleaner on it can I just upgrade to a high flow air cleaner and be fine or do I risk running lean ?
Old May 5, 2007 | 02:11 PM
hillbillyonahawg's Avatar
hillbillyonahawg
Default RE: STAGE ONE question by new guy
I have an 04 1200 custom that has the SE slip-ons and it has also been rejetted.I went with the free flow air cleaner but still run the factory "ham can" cover.It's been that way for two years without any troubles.If the rejet was done right with the carb adjusted properly you shouldn't have any problems.Hope this is helpful.
Old May 5, 2007 | 02:16 PM
cHarley's Avatar
cHarley
It's impossible to know for sure. If the dealer rejetted it on the rich side then you might be ok. Normally changing the pipes does not require a rejet. The rejet is typically done after changing the AC because the increased air flow through the AC upsets the air/fuel ratio.
Old May 5, 2007 | 02:19 PM
Buda's Avatar
Buda
I'll try to see if the dealer has a record of the upgrade and what was done from the previouse owner when I go to the shop today. Thanks
REW13
Carburetor Related
Aug 18, 2018 02:59 PM
Shadowray
Jun 22, 2014 05:48 PM
Hondo11
Apr 7, 2011 01:25 PM
hdridernate
Exhaust System Topics
Feb 21, 2011 10:06 AM
voyager1
May 13, 2007 06:22 PM
