2003 Sportster gearbox removal
Old Oct 24, 2015 | 04:31 AM
gizmogriff's Avatar
gizmogriff
1st Gear
Default 2003 Sportster gearbox removal
Ok so i have fallen off my harley and think i have bend 2nd gear shift fork....
i was hoping someone could give me a rundown on how to remove the 'trap door' gearbox.
i have a manual but am a little confused about which special tools i will need (removing the main shaft etc)
Thanks in advance. Will
Old Oct 24, 2015 | 11:55 AM
JustOneDean's Avatar
JustOneDean
Before you take your transmission apart, why do you think you've bent one of your shift forks?
Old Oct 24, 2015 | 12:04 PM
gizmogriff's Avatar
gizmogriff
1st Gear
Default why i thought
I fell off while i had forward controls fitted.
Now i have put new peg on it and new shifter linkage
- but it now often misses while changing from 1st to 2nd (like being in natural but not as the lights not on - almost like missing 2nd gear) - other times it goes into 2nd fine
- when going from N to 2nd i always get a clicking grinding sound before it engages into 2nd
what do you think? will
Old Oct 25, 2015 | 04:03 AM
JustOneDean
My first thought is, start with the simple fixes and go down the list. I'd check your clutch adjustment. Does this happen downshifting from second to first? Any other gears? Is it hard to find neutral?
Old Oct 25, 2015 | 04:35 AM
gizmogriff's Avatar
gizmogriff
1st Gear
Default Thank you
Well I've adjusted my clutch... It does not happen when downshifting! It it easy to find nutural!
I could take primary cover off and check things?
Old Oct 27, 2015 | 04:49 AM
guitarman023's Avatar
guitarman023
Check the throw on your forward controls from first to second as well, make sure the linkage doesn't hit anywhere preventing a full throw.
Old Oct 27, 2015 | 12:05 PM
brimic's Avatar
brimic
As others have said, check the easy stuff first.
If you need to pull your transmission, you'll know it by the chunks of metal that come out or stick to the drain plug when you drain the transmission oil.
If its not shifting easily or not staying in gear, if I'm not mistaken, those parts/problems can usually be fixed without removing the transmission when dealing with a 5-speed (4-speed trannies are a different animal).
Old Oct 27, 2015 | 12:28 PM
gizmogriff's Avatar
gizmogriff
1st Gear
Default Other things
Ok. So this weekend I will remove the primary cover and clutch and have an inspection (do you think that's is best)? Shall I look at pawl / detent ... If so how?
Architect's Avatar
Architect
Here is the video from Led Sled installing their kick start kit. At least it gives you a great over view of how to take it apart.
This of course is a last resort, do everything listed above first.
Old Oct 27, 2015 | 01:01 PM
gizmogriff's Avatar
gizmogriff
1st Gear
Default Don't have to remove the belt
Oh so in order to remove the tranny do you not have to remove any part of the drive belt (front sprocket)?
