baffled
Old May 7, 2007 | 04:38 PM
Ragin_Republican's Avatar
Ragin_Republican
Default baffled
I just bought a 03' xlh sporty saturday. Only had 1172 miles on it cause the guy I bought it from never rode it. Anyways, brought it home and the wife said it sounded like a lawnmower because it has the stock exhaust with the muffler baffles. [:'(]. First thing sunday morning I got up and knocked the little center part out of the baffle wich made the pipes sound alot better. I have been told that the carb will have to be re-jetted but I have noticed no difference in how it is running or in performance. I do plan to put some straight drag pipes on it in the future though and want to know if I will have to have it jetted. Any input on this?
[IMG]local://upfiles/1542/36DA38DFA9E7422F8CB83D9B6AFE6BD0.jpg[/IMG]
Old May 7, 2007 | 04:42 PM
DelawareDon's Avatar
DelawareDon
Default RE: baffled
If you only plan on non-stock pipes, you may not have to rejet. However, I would stay alert to any symptoms that your Sportie is running lean. If you also go with a high-flow air filter-intake, as well as the pipes, the chances are very high that you will need to rejet.
Old May 7, 2007 | 05:33 PM
Ragin_Republican
Default RE: baffled
thanks for the imput don. Do you or anyone else know if there is a slip on pipe available to replace the stupid muffle ends on the stock exhaust?
Old May 7, 2007 | 08:16 PM
Ragin_Republican
Default RE: baffled
"bump"
Old May 7, 2007 | 08:22 PM
txbikerboy's Avatar
txbikerboy
Default RE: baffled
There are several different slip-ons available. Many people, including me, use the Screamin Eagle II slip ons. If you get these, try for the ones with the baffles bolted in, not welded. Makes removal much easier. These pipes are loud and deep.
Old May 7, 2007 | 08:23 PM
cHarley's Avatar
cHarley
Default RE: baffled
Oxymoron?? Republican = Conservative and you want loud pipes????
Just Kidding
Old May 7, 2007 | 08:26 PM
Ragin_Republican
Default RE: baffled
hell yeah! Loud pipes save lives!! You must have run into a rogue conservative. We're not into telling you what you can and cant do.[8D]
Old May 7, 2007 | 08:28 PM
Ragin_Republican
Default RE: baffled
thanks txbikerboy. If those are the pipes your talking about in the picture, I'm gonna look into it. Thanks for pointing me in the right direction.
nc883
Nov 2, 2011 01:48 PM
TJT84
Aug 23, 2011 04:48 PM
Mike Kautzman
Ironhead
Jun 14, 2011 07:29 PM
seoris
May 9, 2010 05:41 PM
raven28690
Exhaust System Topics
May 18, 2006 01:22 PM
