Puzzled by error code??
Old Apr 20, 2016 | 03:53 PM
Toon1's Avatar
Toon1
1st Gear
Default Puzzled by error code??
My 2011 sporty is reading a code pn 32152-07c. I've tried to research it but not much luck. Anyone know?
Old Apr 20, 2016 | 04:25 PM
Guzzi's Avatar
Guzzi
What you're seeing is a P/N or serial number and not a code. Someone will come along shortly with better details. Nothing to worry about.
Old Apr 20, 2016 | 05:21 PM
elfnyc's Avatar
elfnyc
check the connections to the ecm if loose
and also check the
Ignition module plugs
Old Apr 21, 2016 | 03:59 AM
Toon1's Avatar
Toon1
1st Gear
Default I got it....I think?
I took my bike to my mechanic and come to find out it was my negative side terminal to my battery was loose. When I bought the battery from him and did the install I didn't put the spacers in which caused only a partial contact to the terminal. Today after work I'll find out more when I go to pick up my sporty. But, so far that's looking to be the problem. Thanks for your input though.
Scott Flory
General Topics/Tech Tips
Jul 30, 2018 06:50 PM
rebel7
Jun 11, 2018 08:38 AM
getblended
Jan 24, 2016 08:03 PM
bujerk777
Sep 30, 2015 01:00 AM
gramps50
Jul 7, 2008 07:40 PM
