Vibration after changing slip-ons
Old May 14, 2016 | 08:40 PM
Bluesrider.df's Avatar
Bluesrider.df
Default Vibration after changing slip-ons
2007 XL1200C
I pulled off a pair of Screamin' Eagle Shorty and put back on a pair of Cycle Shack MXL-130 slip-ons, which originally were on the bike when I bought it last year. The Shack's are louder ("real" Harley sound, lol), the SE's are pretty quiet, slightly louder than stock.
Anyway, I'm noticing a lot of vibration that I didn't have before, pretty much all across the rpm range. I recently installed a FuelMoto tuner, I'm wondering if they need to adjust the tune for the different pipes, maybe that will help.
I've checked the pipes, everything is nice & tight.
Anyone?
Old May 14, 2016 | 08:46 PM
RANGER73's Avatar
RANGER73
Different pipes different air flow. Retune is in order.
Old May 14, 2016 | 09:36 PM
hscic's Avatar
hscic
More rumble more vibration...LOL
Not knowing what kind of vibration, a new tune is a good place to start given that you checked all fasteners. Not all pipes are created equal.
Old May 16, 2016 | 07:23 PM
Huggerbugger's Avatar
Huggerbugger
You're not alone. Mine vibrates so bad now, I put it up for sale.
Old May 16, 2016 | 07:32 PM
Bluesrider.df
When you say "now", what mods did you do that it ended up so bad?
I threw my Screamin' Eagle pipes back on, and it's silky smooth again. The bike originally had the Cycle Shacks, and while louder, it didn't have a vibration issue. It's only since getting the tuner that it became an issue. I am awaiting a new map from FuelMoto for the Cycle Shack pipes, which I expect should smooth things out.
Old May 16, 2016 | 07:51 PM
Huggerbugger
Haven't done anything, except change the front motor mounts, thinking that would cure it. Made it worse.
Old May 16, 2016 | 09:18 PM
newtothe48's Avatar
newtothe48
A Harley Sportster vibrate, NO way!!!!!!!
Would agree, probably new tune probably in order.
Old May 17, 2016 | 02:31 AM
BensonUK's Avatar
BensonUK
since I put my slips on on my rear pegs drop down all the time due to the vibration
Old May 17, 2016 | 02:37 AM
Baggyb's Avatar
Baggyb
My Vance and Hines do the same on mine. Especially now I have installed the Kuryakyn wing pegs
Old May 17, 2016 | 06:34 AM
grbrown's Avatar
grbrown
So we have several bikes with a vibration problem, following a muffler change? Doesn't make sense to me, I must confess. There surely has to be a simple answer to this. A pal of mine swapped mufflers recently on his '07 and his bike is fine.
