Idle air control problem
Old May 18, 2016 | 03:05 PM
Kpittmanjr's Avatar
Kpittmanjr
3rd Gear
Default Idle air control problem
Just got a 2009, 1200xl c Sportster.
Has 6400 mi
With the power OFF, the IAC is cycling, and draining the battery.
If I unplug it, battery is fine.
When I put a test light to the wiring harness, all four post are hot.
Even with the key off.
What could be causing this?
Old May 18, 2016 | 08:44 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Hello and welcome to the forum from SoCal.
Old May 18, 2016 | 08:51 PM
cvaria's Avatar
cvaria
Has 6400 mi
pull your codes....:
https://www.hdforums.com/forum/ignit...tic-codes.html
report back..
worst case- the part is $25-35. p/n 27629-01a
isolate the issue first though
Old May 19, 2016 | 01:51 PM
Kpittmanjr's Avatar
Kpittmanjr
3rd Gear
Got a P0122 code.
Can I reset this myself?
Old May 19, 2016 | 02:50 PM
cvaria's Avatar
cvaria
yes. just press and hold the odo button and you will get a prompt to clear it. i would replace it (takes only a few minutes) but, hold tight for the wisdom of the forum.
peci02@bellsouth.net
May 15, 2020 11:31 AM
Kpittmanjr
May 21, 2016 02:48 PM
jameserss
Aug 18, 2014 12:41 PM
harleyfiremedic
Dec 7, 2012 09:27 AM
Brion B
Dec 4, 2011 12:19 PM
